How to Get Water Supply to My Shop Building?
10K views 22 replies 5 participants last post by  psilva8
Built a shop about 350feet from my house and wanna run a water line out there. Maybe a bath room eventually.. and a shop sink, and water spickit. Thinking pex since less joints, will probably be almost 400' and have a couple water spickits in between. Do you think 3/4" will be enough, or should i spring for 1"?? thanks in advance.
Are you on city water or well water? What size is the line coming into the home? You may be limited. A 3/4" line over 400' will experience significant frictional losses. We could get technical and use a hazen williams calc for the sizing but it may be futile depending on the size of your incoming service.
Dont know why i asked without posting that info.. O.D. of pipe directly out of meter is 1" and then goes to 1 1/4" O.D. pvc. I am thinking of running new from my meter cause they ran that thin schedule .... crap is it schedule 22? i messed with it couple years ago and cant remember. Its pretty thin walled stuff though. Schedule 30?
#8 ·
Any idea of the typical static pressure? You need to know that, and the kind of flow rate you wish to achieve then it is fairly simple. Run a quick calc to figure out the head losses with a given gpm flow rate and you will know what the head loss is. You really don't want to get under 20psi and even that is the minimum.
#9 ·
No idea what the pressure is.. forgot to say but its city water but guess me saying meter gave that up. Should I just run 11/4 pex from meter to house (about 100 foot) then go with 1" back to shop (about 370') to be safe? I've had a bunch of hoses together that reached back there and it was at least good enough to water plants wash hands and control a small bonfire.
#14 ·
I have installed irrigation systems with the black pipe and serviced systems that are 25 years old, so reliability isn't an issue. What will be an issue for you is finding it.. I can't get it here in Georgia, it is mainly used in colder climates. If you are for sure digging a trench just use 20' sections of the white PVC. They come with one end blown out so you dont need fitting to join the pipes...you could glue that long of a run together in about 10 minutes. Plus the rigidity of the pipe will make it easier and more durable wherever you have spigots. That is how I do my irrigation now in Georgia. You can get it at Lowes or Home depot
#16 ·
Should I run bigger PVC say 1.5" I know the inlet at meter will still be 1" but guess their would be less restriction in the long run to the back... you can get to big and hurt flow? Or no? In the end do I really need a flow reading.. if so how would I go about that?
#21 ·
I think 1" would be sufficient. Instead of PVC I would advise the use of polyethylene tubing (series 160) pipe if available. You can buy it in coils and it is cheap. It has a thicker walls than the irrigation tubing described earlier and is certified for potable use.
It can also be installed by directional drill if you wanted.
