How To Get Rid Of Old Caulking - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-10-2012, 08:47 PM   #1
hohadcr's Avatar
Rewards Points: 308
how to get rid of old caulking
i need to remove the old caulking around the bathtub to recaulk it.
the old caulking is hard to get rid of. it is messy.
i am using my nails to scratch it off. taking forever.
is there a better way!
thx
hohadcr is offline   Reply With Quote
Old 06-10-2012, 08:52 PM   #2
DIY staff
Rewards Points: 7,174
Single edged razor knife--and time---that's what I do---
Old 06-10-2012, 08:56 PM   #3
Rewards Points: 13,468
Single edged razer blade.
It's all got to go. New will not stick to old.
The area also needs to be very clean.
The best way to reapply is fill the tub 1/2 full of water, apply the caulking, wait 24 hours and drain the tub.
It's weights down the tub and opens up the gap.
Old 06-11-2012, 12:55 AM   #4
Rewards Points: 264
If it's really bad, you can get some caulk remover that will soften/dissolve the caulk. If you use it, just be sure to clean up afterwards. The caulk will return to its original state if allowed to dry. On the flip side, it beats chiseling it out if the caulk has gotten that hard.
a_lost_shadow is offline   Reply With Quote
Bathroom floor/tub and caulking soulstar General DIY Discussions 5 11-10-2011 10:49 PM
Caulking a Bathtub, need advice RealMarkP Plumbing 5 03-12-2011 05:25 PM
caulking tile backsplash--he sprayed something on the caulking then used his finger Limit54 Tiling, ceramics, marble 6 12-06-2010 05:45 PM
Caulking Exterior Windows unixb0y Painting 1 06-04-2009 05:31 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 04:46 PM
