Want to flush our water heater that has solar panels attached. Procedure I want to use for the flush is:
1. Turn off electricity. Turn off cold water to heater and open a hot water faucet.
2. Drain heater completely.
3. Turn on cold water to fill heater about half way to loosen sediment.
4. Repeat steps 2-3 until water runs clear.
My questions deal with the solar panels. When I drain the heater, the water from the solar panels will drain out. I could prevent that by shutting off the two ball valves that are in the lines to/from the solar panels. But if I do the flush during the day, I'm afraid of the thermal expansion issues in the closed loop to the panels. (I prefer not to do the flush at night if possible.)
I would like to just let the water drain out of the solar panels but then I don't know the procedure to bleed the air out of the panels after the flushing is complete.
Here's the valve setup to the solar panels:
Water Heater >--->pump>--->ball valve>--->hose bib>--->solar panel1>---,
Water Heater <----------------<ball valve<---<hose bib<---<solar panel2<---'
What's the correct procedure to use? How do pros do water heater flushes with this type of setup since they would be doing it during the day? I would like any responses on how to bleed air out of the solar panels to come from trained folks and not best guess from untrained folks.
Thanks,
HRG
Thanks,
HRG
