#1 |
How Flush to the Wall does the Drain Stub Go
Replumbing Kitchen Sink. How much should the Drain stubout stick out from the wall. Just enough that the threads + the SJ nut stick out when the 1/2 back of the base cabinets go in ?
#2 |
i like to stub around 6 inches out from wall then after cabinet and sink are installed cut some off if needed to hit p-trap and then glue trap fitting. i like to put it it at 12 inches off of floor and yes that seems real low but i have had to go to a lot of counter top remodels and cut out back off cabinets to lower drain so it will work. due to deep under mount sinks with garbage disposal.
it is amazing how many calls i get from a customer saying they have a easy job just need kitchen sink hooked back up and you get there and old drain is to high
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are 1 poop needs to flow down hill. 2 hot on left cold on right 3 i get a pay check on Mondays 4 do not chew finger nails at or after work. |
| Display Modes | |
| Basement Concrete Wall Framing Against Stairs | Epicsoccer | Remodeling | 7 | 01-13-2013 04:11 PM |
| How to install drain behind foundation wall? | Bahuffma | Building & Construction | 1 | 07-16-2011 02:35 PM |
| Trouble with staggered wall | rightit | Building & Construction | 2 | 03-09-2011 07:23 PM |
| Can't get bathroom vanity flush to wall | mahsully | Remodeling | 11 | 10-25-2009 06:33 PM |
| Marrying a sloping stone wall to a cinder block wall. | mrdol | Landscaping & Lawn Care | 1 | 11-09-2007 05:08 PM |
