How To Fix Wall Mount Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2013, 02:11 PM   #1
how to fix wall mount toilet
hi guys. i am willing to fix wall mount toilet in my bathroom.
it will be on two support system.
i heard that ceramic bowls mostly breaks while fastening to carrier bracket when it come in contact with hard surface of wall tiles
what measures should i take while fastening the bowl?
should i use plywood between the bowl and wall tiles to reduce the braking chances or there is some specific fastening torque?
any help is greatly appreciated
mohdsaif is offline   Reply With Quote
Old 02-24-2013, 02:27 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
I haven't set a residential wall mt. toilet but have done plenty of commercial units. these toilets are held away from the finished wall surface by back up nuts and washers at 3 of the 4 corners. If the 4th corner is tightened down- you run the risk of breaking the bowl. Hope this helps
Can I Move Toilet Drain Into Wall? Toilet Bowl Plumbing 16 06-28-2012 04:06 PM
Leak in PVC behind toilet wall jturk1 Plumbing 4 03-24-2012 05:13 PM
toilet drain is too close to the wall in the basement Kirock17 Plumbing 15 02-24-2010 08:07 AM
Removing spine wall beko Building & Construction 12 02-02-2010 02:15 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
