How To Fix And Prevent Corrosion On Water Heater Lines - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-10-2010, 07:31 AM   #1
How to fix and prevent corrosion on water heater lines
The attached picture is of the two water lines going in and out of our hot water heater. It appears that the lines coming out of the heater are black steel and they have been directly joined to the copper lines. These joints are corroding. What should I do to fix it? I purchased some PEX that I planned to splice in, but thought I should get your opinions first.
boyfly is offline   Reply With Quote
Old 08-10-2010, 08:33 AM   #2
Owner
LateralConcepts's Avatar
I'm guessing you can solder based on you mentioned splicing PEX in. I wouldn't do that, but rather cut the copper lines just a couple inches below the top couplings (just below the 90's) then solder on copper MIP adapters. Eliminate the black iron pipe nipples coming out of the heather and replace them with dielectric nipples, then use 18" copper or stainless steel flex supply lines to make your connections.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 08-10-2010, 08:46 AM   #3
A friend of mine made that same suggestion when he looked at it in person. The only thing that worries me about going that route is that the black pipe appears to be crimped onto the hot water heater... it isn't screwed or soldered on... so I'm not sure how to cleanly remove it without breaking something.
Old 08-10-2010, 08:52 AM   #4
Owner
I've never seen anything like that. Can you take a closer picture showing the nipples going into the top of the tank? Also, how old is that tank? Looks ancient.
Lateral
(208) 818-8241
Old 08-10-2010, 09:40 AM   #5
Licensed Master Plumber
The nipples coming off the tank are perminent and can not be removed. The corrosion is because the copper female adaptors are leaking. take it apart and re-dope the fittings
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 08-10-2010, 09:52 AM   #6
I will post some close-ups to confirm that the nipples are permanently installed.
I thought perhaps the corrosion was because of a chemical reaction between the two metals. Is this not the case?
Old 08-10-2010, 09:59 AM   #7
Owner
Yes it is. Electrolysis. You could simply install dielectric unions between the copper and the black pipe, but black pipe should not be used for water if that's what it is. I would get rid of it all together.
Lateral
(208) 818-8241
Old 08-10-2010, 10:04 AM   #8
Here's a picture at a better angle to see how the black steel nipple is connected to the hot water heater. Also attached is an overall picture of the heater, which is somewhere in the neighborhood of 5-10 years old.
How to fix and prevent corrosion on water heater lines-dsc05709.jpg   How to fix and prevent corrosion on water heater lines-dsc05707.jpg
Old 08-10-2010, 05:37 PM   #9
Rewards Points: 1,514
It looks to me that the black pipe is screwed into the heater.
But this does not mean you can unscrew it easily.
If/when you take apart the copper female screw on adapter from the black pipe up above, the black pipe will have suffered more damage (from corrosion) than the copper piece.
Old 08-10-2010, 05:59 PM   #10
Owner
Your newest picture shows that it's not "black pipe", but appears to be galvanized pipe that's been painted black.
Either way, out with the old... in with the new.
Lateral
(208) 818-8241
Old 08-10-2010, 09:49 PM   #11
DIY staff
Rewards Points: 7,174
That's the goofyist looking gas line --No plumber did that-----
Old 08-10-2010, 11:06 PM   #12
Plumber
TheEplumber's Avatar
Rewards Points: 684
Old 08-10-2010, 11:33 PM   #13
Owner
Must have been the electrician...
Lateral
(208) 818-8241
Old 08-10-2010, 11:39 PM   #14
Civil Engineer
Rewards Points: 4,790
I have a similar hot water heater. I have threaded galvanized pipe coming out of the heater, with a dielectric union to copper. This has worked fine for more than five years, no corrosion. I have never seen a crimped fitting attached to a heater, always threaded, doesn't mean yours isn't crimped, just never seen it.
Galvanized pipe is much more corrosion resistant than black iron, but you absolutely need the dielectric union to prevent corrosion, you can get them at any plumbing store on a big box store.
Daniel Holzman is online now   Reply With Quote
Old 08-11-2010, 12:23 AM   #15
Rewards Points: 352
Wink
this guy sounds like he has done this before
plumberinlaw is offline   Reply With Quote
