How To Fix Pool Pump Leak? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-07-2013, 01:05 PM   #1
Rewards Points: 411
How to fix pool pump leak?
Water is coming out where the white pvc piping screws into the pool pump (off white).
Your guidance here is greatly appreciated!
a1481155 is online now   Reply With Quote
Old 03-07-2013, 01:19 PM   #2
copper
Take it apart, clean the threads, put pipe dope on the threads, and put it back together.
Gerb10 is offline   Reply With Quote
Old 03-07-2013, 02:10 PM   #3
Rewards Points: 334
Looks like who ever did that didn't plan ahead - you are going to have to cut it and put in a union?
tribe_fan is offline   Reply With Quote
Old 03-07-2013, 02:42 PM   #4
Roofmaster
Rewards Points: 2,172
It also looks like the pump housing is cracked, unless im seeing things.
Old 03-07-2013, 05:44 PM   #5
Rewards Points: 710
In my opinion screwed plastic fittings should be illegal to make. If I had any money to bet my money would be on a cracked male screwed fitting, due to vibration, even though the female screwed fitting is often the culprit and it can be heard when it cracks.
That horizontal pipe section needs a rubber coupling of some type or hose to absorb pump vibration. Reassemble with Teflon tape in case you want to disassemble again in 20 years or less.
Old 03-07-2013, 06:32 PM   #6
Rewards Points: 1,770
cut your pipe in the horizontal and unscrew from pump. Teflon tape the fitting then add a touch of pipe dope screw it into the pump and use a fernco as a coupling. Big rubber thing with 2 hose clamps. This will help against it vibrating and leaking again.
Old 03-07-2013, 08:27 PM   #7
Rewards Points: 79
If I had to guess, this has happened before. Or else someone had too many couplings and not enough pipe. Cut, remove, inspect, replace whatever's broken and install a pressure rated rubber coupling as has been suggested when you put it back together.
eclark is offline   Reply With Quote
Old 03-08-2013, 02:19 PM   #8
Rewards Points: 411
That looks like a sealant...
It doesn't appear to be leaking from there.
Old 03-08-2013, 02:25 PM   #9
Rewards Points: 411
FWIW, This pump appears to be too small 3/4hp for in-ground 15x30 w/built in spa plus it also appears to be on it's last leg. If you were considering replacing the pump, would you even bother with this repair?
A Pool Leak - What to Do Now? flowerchick General DIY Discussions 6 11-01-2011 12:47 PM
how to wire 2-phase 240 pool pump doncomp Electrical 2 03-13-2011 08:17 PM
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 05:31 PM
connecting pool pump and pool sanitizer Skippy2 Electrical 5 08-17-2008 08:48 PM
Pool Pump & Light Wiring Nod Electrical 28 07-15-2008 05:49 PM
