How To Fix My Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-09-2012, 05:41 PM   #1
Question
How to fix my shower
I recently purchased my house and found that my shower walls are not really secured into place when you lean on them or put pressure on them they have a lot of flexibility.
Where the 3 corner panels meet at the 2 joints is where it is a problem. Once you put pressure on the corners the caulking overtime starts coming off .
Is there anything I can do to secure these corners better so there is less give so I am able to caulk them with no further problems.
I do not really want to take all of the inserts out and redo the whole shower if I do not have to because they sheet rocked around the corners of the shower so it would be quite a bit of work to do it all correctly and add extra supports behind the shower walls. I have thought about putting shims in the corners while I add extra caulking in the corners then let them dry and seal the seams like you would normally but im not sure it would work.
Please help with any advice.
Judd_86 is offline   Reply With Quote
Old 09-09-2012, 06:07 PM   #2
Rewards Points: 14,290
Really need a picture.
If it's just a cheap glue to the wall enclosure that's most of you problum right there. There really thin.
Old 09-09-2012, 07:17 PM   #3
DIY staff
Rewards Points: 7,174
It sounds like the panels weren't installed correctly,as you said---
Your idea of propping the crack open --cleaning out the old caulk and then re caulking might be a workable temporary fix---
I suggest 100% silicone for its flexibility---to keep the joint neat--consider using a soapy spray like Greased Lightning --appy caulk--spray--then tool with your finger---
Old 09-09-2012, 08:28 PM   #4
As Mike said, I think caulking is a temporary fix.
What I would worry is water penetrating behind those flimsy walls (mold, rot, etc.)
allthumbsdiy is offline   Reply With Quote
Complete bathroom redesign- need help with shower placement Liv Kitchen & Bath Remodeling 0 03-08-2012 12:00 PM
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 08:03 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
