How To Fix Leaking Waste Pipe (picture) - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-16-2010, 11:18 PM   #1
How to fix leaking waste pipe (picture)
Hi,
This is my toilet waste pipe, I cut a little hole in the dry wall and used a web-camera to take this picture:
Close up with the leak:
Looks like it's leaking from the joint between the rings, I can visually see the leak every time I flush the toilet upstairs. I'm new to plumbing and not sure what are these 3 plastic rings for, and the main question - how do I fix this leak?
arhipoff is offline   Reply With Quote
Old 07-17-2010, 07:38 AM   #2
Licensed Master Plumber
Cut the leaking section out and replace it.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 07-17-2010, 07:54 AM   #3
The "rings" are coupling ends. You need to cut out the leaking section and replace it. Most leaks from fitting joints are merely bad glue mistakes,but need to be replaced since there is no repairing them.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Leaking vent pipe? emylime Roofing/Siding 12 04-28-2010 01:47 PM
Cutting into Cast-Iron waste pipe. dOe Plumbing 4 03-29-2010 06:09 PM
Locating Waste Pipe Under Concrete Slab stubits Plumbing 6 03-10-2010 09:55 PM
Toilet waste pipe leaking Louise2910 Plumbing 2 06-27-2008 08:48 PM
Leaking Pipe STEPBK2 Plumbing 1 12-06-2004 12:57 PM
