How To Fix, Leak Under Sink, Disposal - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-05-2012, 07:17 PM   #1
Rewards Points: 83
How to fix, leak under sink, disposal
Hi,
Since new, for 4 years we have had no trouble with the builder's install of the kitchen sink disposal. Lately we found the plumbing at the first connection leaks sometimes when the water is on, but a lot when the disposal is on.
Basically there are no threads coming off the black pipe of the disposal, and this meets with the white PVC with the same diameter pipe and a clear compression type seal. I tried teflon tape and re-tightened with no help.
Does the disposal pressurize the pipes...I just thought it chopped up the food bits? The leak is MUCH worse with the disposal on.
Anyway...is this a proper install requiring a new seal in the white pipes....or is there a better connection I can make?
There is vibration from the housing, as one may expect.
Thanks!
How to fix, leak under sink, disposal-imag0301.jpg   How to fix, leak under sink, disposal-imag0303.jpg
bergerdude is offline   Reply With Quote
Old 02-05-2012, 07:23 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
I'd replace the plastic ferrel and see if it still leaks. Nothing wrong with the set up of the piping. If nothing else get a longer extension tube
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 02-05-2012, 10:04 PM   #3
Rewards Points: 582
Originally Posted by bergerdude View Post
Hi,
Thanks!
yes the set up looks ok..what we do is take some emery paper or steel wool and sand the end of disposal tail piece replace plastic ferrell shoud be ok..ben
Old 02-05-2012, 11:06 PM   #4
Rewards Points: 83
thanks. I wasn't sure if a fernco type
fitting would work better?
I'd hate to have to fix this every 4 years! :-)
Double dishwasher, dble sink garbage disposal dilemma pettychat Plumbing 2 01-12-2012 04:43 PM
Enough Space for Garbage Disposal and Deep Sink? jmai14 Plumbing 5 01-05-2012 08:56 PM
Garbage Disposal and Backed up Kitchen Sink [Video Included] HowToGuy Plumbing 5 02-27-2011 08:30 AM
Slow leak under kitchen sink cdruet Site Help and Suggestions 6 09-06-2010 08:28 PM
New Dbl. Sink / DW / Disposal Installation mehaley Plumbing 6 08-05-2008 11:05 AM
