How To Fix A Dripping Shower Faucet? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-28-2009, 12:31 PM   #1
How to fix a dripping shower faucet?
How do I go about fixing this? Very light dripping, but annoying. Attached is a pic of my shower set-up. Thanks in advance.
walds11 is offline   Reply With Quote
Old 11-29-2009, 12:44 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
If this is a Delta ball valve, you can remove the handle with an Allen wrench in the set screw and slightly tighten the adjustment ring down on the ball that has two (hot & cold) spring-loaded seats against it.
If you don't have a Delta faucet tool, you can insert the tips of pair of needle-nose pliers into the two opposite slots in the little plastic adjustment ring around the inside of the dome cap.
You don't have to even turn off the water for this adjustment. Turn it slightly clockwise to tighten it, but do not overtighten it as it will make it hard to operate and will wear out the internal faucet parts quicker.
Just turn it enough to stop the leaking.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 11-29-2009, 05:27 AM   #3
It's not a Delta value, it's a Moen value. I was able to take the handle off. That is the easy part Do I need to turn the water off to get the cartridge out? I need more help. Thanks!
Old 11-29-2009, 08:18 AM   #4
DIY staff
Rewards Points: 7,174
Yes--Turn the water off first.
1. buy a Moen cartridge removal tool.
2. put a rag over the drain so you don't loose and parts down the drain.
3.remove little brass horse shoe clip.
4. attach removal tool and pull out old cartridge.
5.Using very fine sandpaper-gently clean out the hole-wipe out any crud or grit with a rag.
6.install new cartridge-lube first with the lube included with the cartridge.
7.reinstall little horseshoe clip.
Old 11-29-2009, 08:43 AM   #5
Seems easy enough, but where do I turn the water off at? There is a panel behind the shower. Is there a local shut-off value there?
Old 11-29-2009, 11:12 AM   #6
I am at Lowes right now. Lowes has replacement cartridge part 1225, not 1225B. The part is $19.97. Will this part work? They have the cartridge puller tool, $14.97. Wow, the job will cost me about $35, unless I can find the parts somewhere cheaper.
Old 12-05-2009, 02:47 PM   #7
I picked up the parts today at Home Depot today. I bought the puller and some silicon grease as well which the guy at the store recommended. If I don't need the puller, then I will return it. Someone else said that Moen over-greases the cartridges and recommended that I take cartridge apart and wipe off grease. If I do not, the faucet will open by itself due to heavy grease and water pressure. Is this true? Stayed tuned for the results...
Old 12-06-2009, 10:53 AM   #8
The job was a peice of cake. I did not need the puller, so I will return it. The old cartridge came out very easily. Anyway, I am still getting a little drip after installing the new cartridge. I even noticed a slight drip after I turned the water off at the meter. Does the new cartridge need to break itself in? The drip with the water off at the meter tells me that the problem is not just the cartridge. Ugh!
Old 12-06-2009, 12:30 PM   #9
You should probably flush out the valve. There could be just a grain of sand; tiny ball of solder; rust or scale etc stuck in the valve that's causing the leak. Shut the water off, remove the brass retainer clip and the new cartridge, close the shower curtain/door, turn the water on for a few seconds, shut the water off again, make sure there's no debris or loose sediment either in the cartridge or inside the valve; reinstall the cartridge and brass retainer clip, turn the water back on.
If you're worried about water going down behind the wall, use a plastic trash bag under the valve to deflect the water out into the tub/shower space for that few seconds of flushing time.
Ishmael is offline   Reply With Quote
Old 12-06-2009, 01:30 PM   #10
Thanks for the advice Ishmael. I know there is always some drip right after you turn the faucet off, which may have been what I saw, but it appears fine now. Maybe it was some extra water that was left in the piping? I will keep an eye on it and if it still drips, I will follow your advice.
Old 12-07-2009, 07:46 PM   #11
No dripping :D
My master bathroom shower has the same handle (no tub, just handle and shower head). Same Meon 1225 replacement cartridge?
Old 12-12-2009, 02:23 PM   #12
I need to replace the cartridge in the master bath shower as I stated a few posts above. I pulled the handle and collar off just to check things out. Yep, it's the same Meon 1225 cartridge. I put the collar and handle back on. The handle spins all the way around and does not stop in either direction. I never noticed this before. The shower is still fully functional with the hot-left and cold-right, but the handle spins all the way around. Could I have put it back together wrong? May not matter because I am going to buy a replacement cartridge soon.
Old 12-12-2009, 11:07 PM   #13
Take a look at this parts diagram: http://www.moen.com/shared/pdf/3170pt.pdf
Did you remember to put the "Adjustable Temperature Limit Stop" (Part #10066) back on? You can see it in the second picture you posted above; it's just a chrome sleeve that protrudes through the large escutcheon, and it has a "hump" (for lack of a better word) that stops the handle from turning past a certain point.
Edit: nm...I just re-read your post, and you did put it back on...hmmm
Edit #2: Some of the older Moen valves with the "crystal" handle have a plastic insert that fits up inside the handle before you screw it on. Depending on which way you put it in, it makes the handle mount a little closer or a little further away from the trim plate. Try flipping that piece around and see if that helps. Sorry I couldn't find a parts diagram that shows that piece, but...
Old 12-13-2009, 06:01 AM   #14
All of my faucets have the crystal handle. I don't remember seeing a plastic insert in the handle. I will disassemble the handle again and check it out. Maybe I put the collar (Adjustable Temperature Limit Stop) on backwards?
Old 12-13-2009, 10:44 AM   #15
Attached are two pics. I still can't remember if the handle stopped in either direction before I took it apart yesterday. Maybe I put it back together incorrectly?
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 06:27 PM
Does not fully go from faucet to shower desimonkey Plumbing 1 04-21-2009 03:59 PM
Tub faucet runs when shower is on. Joeurda Plumbing 1 11-30-2008 01:08 PM
Shower faucet replacement - PVC replacing steel? jdm1 Plumbing 2 11-29-2008 12:38 PM
