How To Fix The Bathtub Faucet Dripping? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2013, 12:42 AM   #1
How to fix the bathtub faucet dripping?
Hello! My bathtub faucet drips. See the picture. I have labeled 1, 2 and 3 on the three parts of the bathtub faucet.
What is this kind of bathtub faucet called and which part should be removed to be fixed, only the Part 2 or all three parts? Thank you for your help?
compiler is offline   Reply With Quote
Old 02-24-2013, 06:40 AM   #2
Rewards Points: 1,216
Shut the water off and take apart #1 and remove the insides and go get a new one or rebuilding kit. replace it. turn it on.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 02-24-2013, 06:46 AM   #3
Rewards Points: 13,732
If you can see a brand name some place on #1 Or can ID it somehow most manufactures will send you the new cartrage for free.
Old 02-24-2013, 06:56 AM   #4
DIY staff
Rewards Points: 7,174
Yep--number one--single handled mixer valve----it needs a new cartridge----
If you can remove the handle and cover plate----and post a picture of the valve---
Someone here might recognize the brand-----
Old 02-24-2013, 10:28 AM   #5
What to do next?
The bathtub faucet is the Peerless. Is it called single lever bathtub or shower faucet? I have removed the collar. Here is the picture.
The blue guard has instructions, “Remove this guard before installing trim.”
Not like the sink water house that it is usually below the sink, the pipe of the bathtub faucet is behind the wall. How to shut off the water supply, from the outside? Can you tell how to do next after the collar has been removed as well as what tool is needed? Thank you.
Old 02-24-2013, 07:04 PM   #6
DIY staff
Look under the handle for a screw---remove that with an Allen wrench and take another picture.
Peerless is not a popular brand----
make calls to parts places and see if the parts are available locally.
Old 02-24-2013, 07:12 PM   #7
Rewards Points: 582
remove set screw from handle assy...install new cartridge ..delta.or peerless will work...ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
COLDIRON (02-25-2013)
Old 02-25-2013, 07:09 AM   #8
If your problem is the faucet dripping, you should first turn off your water source first then examine where could be the damage. Then, you should contact your trusted and reliable plumber. They could do the best thing than you can do and it would be best if it is done professionally and efficiently.
scottharrison is offline   Reply With Quote
Old 02-25-2013, 09:52 AM   #9
I could not see the Peerless bathtub faucet in the HD but Delta and Mono faucet. I wonder whether the Delta faucet and pipe are compatible with the Peerless.
Old 02-25-2013, 09:58 AM   #10
Rewards Points: 528
Most likely not.
Call the plumbing supply houses near you, they will either have it or direct you to where you can buy.
you can buy online also.
http://www.plumbingsupply.com/peerless.html
framer52 is offline   Reply With Quote
Old 03-07-2013, 09:17 PM   #11
Got the Installation Guild
Hi! I have asked the Peerless about the model of my Peerless leaky tub faucet. They identified it is the model PTT188752 tub/shower faucet. They provided me with an installation guild. I have two questions. 1) Should I replace the Valve Cartridge and request the part, Repair Kit RP70538? I have removed the Escutcheon. You may see the picture in my early posting. 2) After I removed the Level Handle with the set screw, the rest of the parts have no screws and thread and I just need to pull them out one by one, the Trim Sleeve, O-Ring and Trim Sleeve until the Valve Cartridge. Is it correct? Thank you for your help.
Tags
Bathtub faucet won't stay depressed to direct water to shower head ferrugia Plumbing 13 02-27-2013 09:39 PM
New Moen Cartridge Is Still Leaking on Bathtub faucet rliu Plumbing 7 01-14-2013 08:49 AM
MOEN bathtub faucet: stuck open romegta Plumbing 10 12-17-2012 03:41 PM
Bathtub faucet leaks from screw hole under faucet. Debmmill Plumbing 3 02-13-2011 06:43 AM
Very low pressure on bathtub faucet/ showerhead Mermarisa Plumbing 7 10-10-2009 11:47 PM
