-   -   How to fix bathroom sink drain pipe ? (http://www.diychatroom.com/f7/how-fix-bathroom-sink-drain-pipe-64916/)
cprao 02-20-2010 12:14 AM
While I fixing new faucets, the bathroom sink drain pipe is punctured. It seems that area was already damaged.. I am not able to figure it out whether it is threaded or soldered..
Here are the fixtures.. Can you please let me know how to fix them ?
Pics are here:
http://i699.photobucket.com/albums/v...e/P2190093.jpg
http://i699.photobucket.com/albums/v...e/P2190092.jpg
http://i699.photobucket.com/albums/v...e/P2190091.jpg
plummen 02-20-2010 12:23 AM
back the nut off the galvanized pipe nipple and the one on top of p-trap and pull both pieces and replace :thumbsup:
cprao 02-20-2010 01:56 AM
Ok. Thank you.. pull the piece off.
Pics:
http://i699.photobucket.com/albums/v...e/P2190094.jpg
http://i699.photobucket.com/albums/v...e/P2190095.jpg
http://i699.photobucket.com/albums/v...e/P2190096.jpg
http://i699.photobucket.com/albums/v...e/P2190097.jpg
Now I just need to get a connecting piece, right ?
How do I measure the length ? or should I carry broken pieces to HD to get a matching one ? or is there a standard length and angle for this drain pipes ?
Dairylander 02-20-2010 03:43 AM
That's a standard p-trap. But it's always good to take the parts with you to your local hardware store to make sure you have the right diameter, etc. The length of the pipe that runs horizontally into the galvanized pipe may need to be shortened. Use the old piece as a template. They are easily cut with a hacksaw or reciprocating saw, then deburr the cut edge with a file before installing.
rjniles 02-20-2010 07:39 AM
It looks like this trap is located in a cabinet. Since it is not a cosmetic issue I would replace with a PVC trap instead of using brass like your existing. Easier to cut and install. And much cheaper.
cprao 02-20-2010 10:19 AM
OK.Thank you. Let me look for it.
cprao 02-23-2010 12:02 AM
Thank you for all.. I bought plastic P trap and fixed it..
However, there is still one issue.. the drain line going out has metal nut and since my P trap is plastic.. I am not able connect these two pieces correctly.. this is causing leak..
plummen 02-23-2010 03:13 AM
use the plastic nuts and washers that came with the trap
cprao 02-27-2010 04:37 PM
Platic nut can't go through the steel pipe I have it.
Here is the setup. I don't have steel nut to for the sink pipe. Either I have to purchase the steel nut so that I can fix the steel trap..
Or
to fix the plastic one, I need to take off the steel pipe from drain line, which I don't want to do.. unless I need to.. since this seems to be more work here.. if I do this, then I can fix the plastic one end to end..
Any other thoughts ?
http://i699.photobucket.com/albums/v...e/P2270106.jpg
http://i699.photobucket.com/albums/v...e/P2270107.jpg
http://i699.photobucket.com/albums/v...e/P2270108.jpg
http://i699.photobucket.com/albums/v...e/P2270109.jpg
PS: Just now in my area, I am experiencing hailstrom.. looking great as I see through the window.. Whole my backyard is covered with snow.
Five Arrows 02-27-2010 08:15 PM
Looks nasty
Normally this stuff just screws compression fittings. If I couldn't get it off I'd cut it with a hack saw and go back with plastic fittings you can find a Lowes or Home Depot. The black plastic in the back I wouldn't cut. If you twist on the threaded end (rightie tightie lefty loosie )it will come loose.
You shouldn't have a problem going metal to plastic, but if nothing worked you may need to replace the material into the sink. Probably needs a new drain anyway. Normally a bathroom sink is 1 1/4 inch pipe but to the prior post take the pieces with you to the store and buy extra parts.
Whenever I replace these I start at the wall and go into the sink with all new.
