Old 04-24-2009, 03:17 PM   #1
How to fit a closet bend in a 2x8 ceiling cavity
I'd like to finish our basement ceiling, but the copper closet bend for the 1st floor toilet extends below the 2x8 joists. I'll be replacing the copper with PVC. Can you folks conceive of a combination of fittings that would enable me to conceal the toilet plumbing in the ceiling without resorting to a soffit?
benjamincall is offline   Reply With Quote
Old 04-24-2009, 03:41 PM   #2
I'm pretty sure you will not have a problem fitting a 3" closet bend in there. A closet bend is a little tighter radius than a "regular" DWV elbow. It is very possible your copper fitting is not a closet bend.
Rege
RegeSullivan is offline   Reply With Quote
Old 04-24-2009, 04:03 PM   #3
Rege
Do I need much of a vertical piece between the bend and the flange piece?
Old 04-24-2009, 04:12 PM   #4
You can set the flange right on, or in the hub of the closet bend depending on the flange you get. You do not need a vertical piece.
Rege
Old 04-24-2009, 05:36 PM   #5
Thanks, Rege! I was worried I might impede the flow of . . . uh . . . waste if I didn't have a little more of a straight run before the bend.
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
No-Hub Cast Iron Closet Bend / Closet Flange lazypants Plumbing 10 06-11-2009 11:48 AM
Toilet Leaks When Flushed - How to get at closet bend!! OldHouseNewProblem Plumbing 3 12-11-2008 07:24 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
