-   -   How to fit a closet bend in a 2x8 ceiling cavity (http://www.diychatroom.com/f7/how-fit-closet-bend-2x8-ceiling-cavity-43179/)
benjamincall 04-24-2009 03:17 PM
I'd like to finish our basement ceiling, but the copper closet bend for the 1st floor toilet extends below the 2x8 joists. I'll be replacing the copper with PVC. Can you folks conceive of a combination of fittings that would enable me to conceal the toilet plumbing in the ceiling without resorting to a soffit?
RegeSullivan 04-24-2009 03:41 PM
I'm pretty sure you will not have a problem fitting a 3" closet bend in there. A closet bend is a little tighter radius than a "regular" DWV elbow. It is very possible your copper fitting is not a closet bend.
Rege
benjamincall 04-24-2009 04:03 PM
Rege
Do I need much of a vertical piece between the bend and the flange piece?
RegeSullivan 04-24-2009 04:12 PM
You can set the flange right on, or in the hub of the closet bend depending on the flange you get. You do not need a vertical piece.
Rege
benjamincall 04-24-2009 05:36 PM
Thanks, Rege! I was worried I might impede the flow of . . . uh . . . waste if I didn't have a little more of a straight run before the bend.
