How To Find And Shut Off The Main Water Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-07-2011, 05:36 PM   #16
Experienced
Jackofall1's Avatar
YW, time to go pick the wife up, take care! Open a CW tap to relieve pressure before you cut the line.
Old 01-08-2011, 09:35 AM   #17
Owner
LateralConcepts's Avatar
If your vanity fits tight against 2 or more walls; once you cut the PEX below the angle stops, you're gonna have a heck of a time putting the vanity back in place when you're finished. Lining up the PEX with the existing holes in the cabinet will prove nearly impossible.
While you have the vanity out, I would suggest either enlarging the holes for the water lines or use a saw to cut out the bottom of the cabinet behind the "base board skirting" (for lack of a better term) so your hands will fit underneath to help guide the water lines back in place.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Price Pfister 3 Valve Shower Replacement water issue LeviDIY Plumbing 3 06-18-2009 01:59 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 07:48 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
