How To Find And Shut Off The Main Water Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-07-2011, 05:03 PM   #1
How to Find and Shut Off the Main Water Valve
I just wanted to tile my bathroom floor. Turns out I am going to have to remove the bathroom vanity. In order to do that, I have to find the main water line shut off, so I can turn off the water to my house, cut the tips of the sink lines and cap them off. I attached a photo of one of the sink lines. (Well, I actually have a different shut off valve I am going to put on the sink lines). But, I do not remember where the Main Shut off valve for my home is. I don't even know what it is supposed to look like.
My home is only 10 years old. Built in Northern UT. Any thoughts on where to look for it? What it might look like? Please, I need help fast. I just want to get my project done.
PUTP is offline   Reply With Quote
Old 01-07-2011, 05:11 PM   #2
Do you have a basement, crawl space, .... slab ?
Utility room anywhere
Old 01-07-2011, 05:15 PM   #3
The water heater and furnace is in the basement. I also have a laundry room next to my family room on the ground level. The bathroom is on the second level.
Old 01-07-2011, 05:17 PM   #4
Experienced
Jackofall1's Avatar
Main valve will have typically a gate valve, union, meter, union and then another gate valve, it will either be through the concrete floor or low on the foundation wall.
Old 01-07-2011, 05:42 PM   #5
would it maybe be near the water heater?
Old 01-07-2011, 05:47 PM   #6
What does a gate valve look like?
Old 01-07-2011, 05:49 PM   #7
Our electric and gas meter are outside, on the north side of our house. but I dont' know that i have seen a meter for the water... geeze. I am so lost with this. grr.
Old 01-07-2011, 05:51 PM   #8
Experienced
Jackofall1's Avatar
I wouldn't know if its near the water heater, the gate valve is not important if you are not familiar with one, the thing to look for is a water meter, or a pipe coming through the concrete either on the wall or in the floor.
Old 01-07-2011, 05:52 PM   #9
Experienced
Jackofall1's Avatar
Gas and electric are typically outside, because they don't need freeze protection.
Old 01-07-2011, 05:52 PM   #10
Experienced
Jackofall1's Avatar
Follow the cold water pipe back from the HW tank.
Old 01-07-2011, 06:27 PM   #11
Sorry to be a bug....
are either of these it?
Old 01-07-2011, 06:29 PM   #12
Experienced
Jackofall1's Avatar
Looks like you found what you were in need of, by the way that is a pressure reducing valve between the 2 ball valves.
Old 01-07-2011, 06:31 PM   #13
Yay! Now do I turn them both off?
Old 01-07-2011, 06:32 PM   #14
Experienced
Jackofall1's Avatar
THe one closest to the floor to be certain from that photo
Old 01-07-2011, 06:34 PM   #15
Oh Tay! I'll give it a shot. thank you so much for you speedy help. I really do appreciate it.
Price Pfister 3 Valve Shower Replacement water issue LeviDIY Plumbing 3 06-18-2009 02:59 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 08:48 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
