How Far To Open Toilet Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-19-2013, 02:07 AM   #1
How far to open toilet valve
Probably a dumb question, but how far should you open your toilet valve? I recently replaced my fill valve, and the original installer of the toilet had the water supply valve on the toilet wide open. I opened probably about a third of the way (thinking that perhaps wide open is too much pressure) but is there standard, such as- open it wide open and then back off a quarter turn or something like that? Please advise.
-Segal
segal is offline   Reply With Quote
Old 04-19-2013, 02:35 AM   #2
Rewards Points: 744
Typically, all the way open.
Seattle2k is offline   Reply With Quote
The Following 2 Users Say Thank You to Seattle2k For This Useful Post:
oh'mike (04-19-2013), segal (04-19-2013)
Old 04-19-2013, 08:19 AM   #3
Rewards Points: 6,652
All the way open. You want the fastest fill.
The Following User Says Thank You to gregzoll For This Useful Post:
segal (04-19-2013)
Old 04-19-2013, 08:26 AM   #4
Rewards Points: 13,300
The valve controls flow not pressure.
segal (04-19-2013)
Old 04-19-2013, 08:39 AM   #5
Rewards Points: 718
Those angle stop valves should be fully open because they have a back seat to prevent leaking in case the stem packing leaks . If the stem packing leaks a little while operating the valve it usually stops leaking when the back seat is reached in the fully open position .
The Following User Says Thank You to SeniorSitizen For This Useful Post:
segal (04-19-2013)
Old 04-19-2013, 09:23 AM   #6
That settles that question! Thank you all for the responses. I must have just been a bit na´ve assuming the valve is related to governing the amount of pressure on the toilet fill valve, but fully open it is
Old 04-19-2013, 11:16 AM   #7
Rewards Points: 582
yep open all the way
Delta shower valve replacement on exterior wall muellertr Plumbing 6 01-02-2013 08:07 AM
Fireplace new gas valve will not open Eltano HVAC 6 10-07-2012 11:00 PM
Removing anti-siphon valve from a toilet tank Chris0516 Plumbing 7 09-30-2012 06:09 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 11:46 PM
