How Is DWV Pipe Routed Through A Lavatory Wall? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-05-2010, 06:14 PM   #1
DIYer
Rewards Points: 93
How is DWV pipe routed through a lavatory wall?
Does anyone have a digram perhaps?
2" pipe through a 2x4 would not work so what must be done? Thicker wall?
Thank you in advance
dwoloz is offline   Reply With Quote
Old 08-05-2010, 08:44 PM   #2
Rewards Points: 276
This is what I found behind my lav wall. Yes, thicker walls. A 6" wall will accommodate a 3" vent pipe. Hope this helps
Jim F is offline   Reply With Quote
Old 08-05-2010, 09:01 PM   #3
DIYer
Rewards Points: 93
Much appreciated! I'm visual when it comes to learning so the picture is very helpful. Thanks
For modifying old construction, I suppose adding another 2x4 bottom plate would be recommended, yes? Is it then feasible to drill a 3" hole in the seam between the two plates? Would the plates have to be structurally tied together with metal then? What about at the ceiling?
Old 08-05-2010, 09:04 PM   #4
My last house was 2x6 "wet wall"
This house has (2) 2x4 walls...seperated by a few inches
Old 08-05-2010, 09:27 PM   #5
Electrician
Proby's Avatar
Yeah, I've seen (2) 2X3 walls with all the plumbing in between them so there was no drilling at all.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-05-2010, 10:29 PM   #6
Owner
LateralConcepts's Avatar
A lav drain is typically 1 1/2" or 1 1/4"
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 08-05-2010, 10:31 PM   #7
Electrician
Proby's Avatar
What size hole is recommended for 2" DWV?
Is it legal to drill that hole in a 2X4?
Old 08-05-2010, 10:36 PM   #8
Owner
2" PVC = 2 1/2"
You can't drill a hole that size in a 2x4.
You only need 1 1/4" for a lav drain.
Lateral
(208) 818-8241
Old 08-05-2010, 10:41 PM   #9
Owner
I don't know all the legal stuff, but just found this thread. Appears to be good information.
http://www.paconstructioncodesacadem...843fd0bf58a88d
Lateral
(208) 818-8241
Old 08-05-2010, 10:42 PM   #10
DIYer
Rewards Points: 93
Can you explain what size the vent should be and how that goes through the top and bottom plates
Old 08-05-2010, 10:46 PM   #11
Owner
That will depend on the number of fixtures it's serving. In which case you would need to look at a sizing chart in a local code book
Lateral
(208) 818-8241
Old 08-05-2010, 10:49 PM   #12
DIYer
Rewards Points: 93
For example, just a simple lavatory with shower/tub, sink and toilet. Nothing else on that vent.
Old 08-05-2010, 10:51 PM   #13
Owner
Without looking at a chart, I would say 2" is sufficient.
Lateral
(208) 818-8241
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
Double wall pipe Captflx HVAC 4 06-09-2009 12:10 PM
shower head pipe snap inside of wall? snosurfa7 Plumbing 3 06-06-2009 09:15 PM
Fixing leaking shower head...turns out pipe coming out of wall is the source plumbingboy9317 Plumbing 5 05-25-2009 01:41 PM
Sound dampening advice needed steel1 General DIY Discussions 10 10-22-2008 01:51 AM
