How To Drain Toilet Without Tank? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-01-2010, 08:39 PM   #1
DIY Apprentice
tripflex's Avatar
How to drain toilet without tank?
Alright so last night i had a party at my house. I go into my bathroom to take a piss and my entire bathroom and closet are flooded in water. The entire tank is broken and water is spewing everything.
Needless to say NOBODY owned up to it and basically i was stuck with cleaning my bathroom all night.
Not a good party and probably won't have another one.
Anyways some ******* i guess decided to piss in my ****ing toilet after i cleaned everything up!
So now i have to replace my toilet but the bowl is full of stale nasty smelling piss.
Please someone help me out here, how do i make this thing drain!?
"How else am i supposed to build my tool collection and owe home depot lots of money? That's why I DIY"
2,200 SQ ft 3/2 Lake house with in-ground pool: http://picasaweb.google.com/tripflex
Help us help you by posting pictures with your question!
tripflex is offline   Reply With Quote
Old 06-01-2010, 08:41 PM   #2
Leak Master
Shopvac, sponge, or if you pick it up and keep it level, you might not spill it out.
O'Leaky is offline   Reply With Quote
Old 06-01-2010, 08:55 PM   #3
DIY Apprentice
tripflex's Avatar
haha maybe a shopvac but sponge no way! It's like a full toilet bowl. I was afraid of shopvac being my only option.
Old 06-01-2010, 09:54 PM   #4
Fill a bucket with water and pour it quickly into the bowl and the toilet will flush the same as if the tank was there. Then all you need to do is siphon out the clean water to empty it.
The Engineer is offline   Reply With Quote
Old 06-01-2010, 10:13 PM   #5
fabrk8r
fabrk8r's Avatar
The Engineer is correct...that was going to be my advice. Quickly dumping a bucket of water into the bowl is the quickest and easiest way to manually flush a toilet and will only leave a cup or two of water which can be scooped out with a small cup (liquid laundry soap measure) or wicked up with a rag.
If it's full to the brim you are going to have to siphon a few inches off first, and as already suggested, a wet vac is first choice otherwise it's like bailing a boat. A little bleach will sanitize anything that came in contact with urine.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 06-01-2010, 10:14 PM   #6
A turkey baster will suck out the water quite well. Never tried the shop vac, but it would be quicker
roger2386 is offline   Reply With Quote
Old 06-01-2010, 10:39 PM   #7
DIY Apprentice
tripflex's Avatar
Ok i think im gonna try the bucket idea, do i pour it into the actual bowl itself or the hole on the back of the toilet where the tank use to be?
Old 06-01-2010, 10:45 PM   #8
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
in the bowl
Old 06-02-2010, 09:27 AM   #9
Rewards Points: 1,448
Originally Posted by fabrk8r View Post
If it's full to the brim you are going to have to siphon a few inches off first, and as already suggested, a wet vac is first choice otherwise it's like bailing a boat. .
If the toilet bowl was full to the brim, that means it is clogged and bailing out a few inches and quickly adding more may or may not dislodge the clog.
After bailing out a few inches from the overflowing toilet bowl, use a plunger and/or snake.
Once you get the toilet to flush using a bucket of water, repeat a few times in quick succession and then bailing out what remains in the bowl won't be so nasty.
Toilet Tank Movement dschucky Plumbing 2 05-04-2010 01:41 PM
Bubbles In Toilet Tank JCNimmo Plumbing 2 01-29-2010 09:11 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 11:14 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
