How To Drain (pump) Washing Machine Upwards? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-06-2013, 05:59 AM   #1
Rewards Points: 91
how to drain (pump) washing machine upwards?
Hello -
I need to relocate my washing machine in my basement where the only option is pumping it upwards. It would pump up to a new horizontal run of 2" PVC, which connects to an existing run of 2" going to the stack. The overall run back to the stack would be about 11-12'.
Assuming the height that it needs to pump is not a problem (< 96"), I have a few other questions:
1. How does one actually connect the washing machine hose to the vertical pipe? Can the vertical pipe be 1.5" PVC or does that need to be 2" as well?
2. Does the vertical pipe join the horizontal run with a standard 90 deg. fitting?
3. I read somewhere that an AAV should be mounted where the horizontal and vertical pipes meet. Is that required?
debiasio is offline   Reply With Quote
Old 11-06-2013, 06:11 AM   #2
DIY staff
Rewards Points: 7,174
You will not be connecting the washer hose to an overhead pipe.
Go to a plumbing supply house and buy a septic pump/box---the machine will drain into that,using a stand pipe and P-trap----then the septic pump will lift the sewage into the house hold drains.
Old 11-06-2013, 06:13 AM   #3
DIY staff
Old 11-06-2013, 06:21 AM   #4
Rewards Points: 13,450
If I went that route I'd also invest in an auto shut off.
Pump fails, it shuts the incoming water off.
http://www.ebay.com/itm/Flood-Stop-S...item43c0a24e86
Old 11-06-2013, 01:39 PM   #5
Rewards Points: 91
Thanks for the feedback.
Looks like the ports are threaded. Is threaded PVC pipe available or would I need to do it myself?
For the vent port, the manual says it should be connected to a "house vent". Is that referring to the vent at the main stack? I'm not able to make that connection. Can I just connect another piece of vertical PVC to it and make its own stack?
Old 11-07-2013, 03:04 AM   #6
DIY staff
You should be able to find a vent somewhere--if not an AAV (air admittance valve) might work----I doubt if that would be code compliant--by it's better than no vent.
Yes, threaded PVC fittings are available--I have never used that brand of box--I just posted that picture for a reference.
Old 11-07-2013, 08:17 AM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 562
AAV's won't work for a pump. The basin pulls in air as well as displaces air as the water level inside changes- AAV's will not allow that to happen
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
Javiles (11-07-2013), jaydevries (11-18-2013)
Old 11-07-2013, 09:34 AM   #8
Rewards Points: 29
You also have to watch what the septic pump box pumps into. You will not be able to connect the pump into an existing 2" line. The pump will put a lot of water into the drain very fast. Once the water hits the regular drain and gravity takes over it slows down, and the pump keeps pumping and it can back up very quickly. Depending on the GPM of the septic pump, you will most likely need to connect it to a 4" line. Some codes also dictate that the septic basin have a dedicated vent all the way to the roof, which can be very hard to achieve. As stated, an AAV will not work at all.
cube17576 is offline   Reply With Quote
The Following 2 Users Say Thank You to cube17576 For This Useful Post:
Javiles (11-07-2013), oh'mike (11-10-2013)
Old 11-18-2013, 06:38 AM   #9
Rewards Points: 91
The documentation for the pump shown in this thread says not to use an AAV with it. So I wouldn't be going that route.
Is there code that specifically states you need a septic pump for this particular type of application, or is it just a good practice?
Old 11-18-2013, 06:28 PM   #10
Rewards Points: 1,866
Normally what folks do around here is install a laundry sink. It drains to a bucket sump. Washer drains to laundry sink. Bucket sump must pump to 4 inch pipe. Vent on sump can be a pipe up to the floor then turn it down. Since it what we call a grey water waste the smell is minimal. Grey water is water that doesn't receive human waste. The pump tie in should be as far away from fixtures preferably 10 foot.
https://www.acwholesalers.com/Little...FeMRMwodvx4A6g
You will ALSO NEED A SUMP CHECK VALVE.
http://www.pexsupply.com/Zoeller-30-...FetcMgodFRkAMQ
This is installed on the sump discharge in a vertical position.
Old 11-18-2013, 11:02 PM   #11
OP,
Here's a product that may work for you, http://www.saniflo.com/homeowners/sfa-product-line/sanivite-%C2%AE.
VIPlumber is offline   Reply With Quote
Old 11-19-2013, 07:52 PM   #12
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
5 gallon bucket in the ground and a sump pump
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Washing machine drain leaking kf30 Plumbing 2 04-16-2013 08:21 PM
Washing Machine Drain Through Brick Wall? rkersh409 Plumbing 11 03-11-2013 08:12 PM
Building a Washing Machine Drain Pan wiz561 General DIY Discussions 8 04-03-2011 02:51 PM
Washing Machine Drain Pipe overflows evol200 Plumbing 3 01-27-2011 12:41 PM
washing machine drain pan mark123 Plumbing 9 09-08-2010 06:50 PM
