How Does This Plumbing Look? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-28-2013, 06:01 PM   #16
Plumber
TheEplumber's Avatar
Rewards Points: 904
If you replace that DWV copper with PVC, then recycle the copper I bet you'll just about pay for your project
Old 08-28-2013, 09:37 PM   #17
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
Originally Posted by Oso954 View Post
Not only a good idea, but may be required. How big is your laundry sink ?
I'm fairly certain that the Ontario Electric code requires any receptacle within 1.5m of the sink edge to be GFCI protected.
But it would be a good idea to do it, regardless of the distance.
I'd have to measure but pretty sure the sink is further away, I was thinking more of the washer, in case a hose bursts or something. But guess if that happens, the electrical would be the least of my worries. Water damage everywhere would be. I could put a GFCI for the washer but kinda pointless when the big 240 dryer outlet is there too. What is typically the code for laundry rooms? I'm sure it's common to have both those outlets fairly close to water pipes/faucets.
Did not replace the DWV lines but did replace a bunch of supply copper:
Think that is worth bringing to the recyclers?
Peninsula Sink removing Pony wall becomes Island Plumbing? lothia Plumbing 6 04-30-2013 12:13 PM
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 04:06 AM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 12:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
