How Does This Plumbing Look? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-13-2013, 08:41 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 70
How does this plumbing look?
My first time doing plumbing involving more than a couple minor runs.
I'm sorta nervous about how some places are rather stiff and it was hard getting the lines to go from the ceiling to the wall as I could not really crimp inside that small space so had to do it ahead of time, which put lot of stress on the pipes while trying to get it in.
Nothing leaks and it works. Is there any chance that something randomly lets go if not done right or has too much stress? Or am I just being paranoid? Plumbing actually does scare me more than electrical but I still want to conquer it myself.
Does this plumbing look ok or should I do anything differently? Hoping it's fine, and that I'm just worrying for nothing. It's been on for a while now with no leaks.
Also I'll be getting the walls spray foamed. I'll make sure the pipes arn't completely covered as to ensure they stay on the hot side, but is there any danger if the insulation gets on it, such as weird reactions with the plastic or something?
Old 08-13-2013, 08:54 PM   #2
Rewards Points: 13,296
Not in love with those style valves or how you stubbed them out of the wall.
Are those full flow valves?
The way you stubbed them out there's no easy way to replace the valve if it leaks.
I would have ran them to a washer box so I'd have a place for the drain and the valves that would look better.
Or at least used a Pex copper stub out.
http://www.watts.com/pages/_products...s.asp?pid=3226
Old 08-13-2013, 09:02 PM   #3
Wire Chewer
Rewards Points: 70
TBH I was hoping to find something that would be easier to mount like some kind of faucet attachment or something, but it was the only thing I could find.
Guess worse case scenario if ever I do need to replace them, there is probably enough room to crimp a union and another piece of pex to work off of.
How is this normally done? Looking at my toilet and sink upstairs (done by a pro) it's similar, except there's no piece of wood or anything, but I wonder how the drywall would have been installed... guess it was done after the toilet and sink were put in, so it would have been easier. Guess I could have done that too, just let it loose and remove the sink and washer to put the drywall and just slide it into a hole. I always have that option when it does come to putting the drywall in, I can just remove that piece of wood.
Old 08-13-2013, 09:12 PM   #4
Wire Chewer
Rewards Points: 70
On a side note, do those outlets need to be on a GFCI breaker?
Old 08-13-2013, 09:34 PM   #5
Rewards Points: 2,634
Probably need a few of these on the studs where you have lines running thru them.
(.png seems to have a problem uploading, but .jpg seems to upload readily)
SPS-1 is offline   Reply With Quote
The Following User Says Thank You to SPS-1 For This Useful Post:
COLDIRON (08-14-2013)
Old 08-13-2013, 10:04 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 452
You should isolate the pipes off the wood when going through the studs to reduce wear and noise transfer.
Also, stub the pex out further at the stops for future repair.
These washer boxes work good- should be able to get them at the box store
Old 08-14-2013, 09:29 PM   #7
Wire Chewer
Rewards Points: 70
What is the proper way to isolate the pipes? For the top I shoved some foam in there, is there a better way? Everything is fairly tight. I'm also wondering, can something be TOO tight, and be a future danger? Or will the pex "get used" to the way it is and have less stress over time? I also did my best to ensure the holes don't have sharp edges by passing a chisel around to get rid of pointy bits.
When I do come to do the drywall, I may also get rid of the piece of wood, and just cut a hole in the drywall to pass the valves through, that should give about an inch of extra slack, so maybe 2 inches total.
Old 08-14-2013, 09:37 PM   #8
Plumber
Rewards Points: 452
Stick some of these in the stud holes- anchor them with some screws.
Your pipe will need to expand/contract a little. These help protect the pipe.
http://www.homedepot.com/webapp/cata...gry=Search+All
Old 08-21-2013, 10:21 PM   #9
Master Plumber
Javiles's Avatar
Rewards Points: 990
I understand that varmints love that plastic stuff.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
ben's plumbing (08-28-2013)
Old 08-21-2013, 10:53 PM   #10
Plumber
Rewards Points: 452
Termites love wood too, but we still mill lumber
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 08-22-2013, 10:00 PM   #11
Master Plumber
Javiles's Avatar
Rewards Points: 990
Oh a wise guy yeah!! yuck yuck yuck,
TheEplumber (08-22-2013)
Old 08-28-2013, 11:56 AM   #12
Rewards Points: 131
Some of these bend supports would have saved you a little time and quite a few crimps:
http://www.pexsupply.com/Wirsbo-Upon...port-2128000-p
HitLines is offline   Reply With Quote
Old 08-28-2013, 12:34 PM   #13
Rewards Points: 170
also would have provided slightly better water flow/ pressure... nothing wrong with 90 degree elbows though. worked for copper for years.
diyer111 is offline   Reply With Quote
Old 08-28-2013, 04:31 PM   #14
Rewards Points: 2,238
Not a bad idea!
rossfingal is offline   Reply With Quote
Old 08-28-2013, 06:57 PM   #15
Oso954's Avatar
Rewards Points: 760
Not only a good idea, but may be required. How big is your laundry sink ?
I'm fairly certain that the Ontario Electric code requires any receptacle within 1.5m of the sink edge to be GFCI protected.
But it would be a good idea to do it, regardless of the distance.
Oso954 is online now   Reply With Quote
Peninsula Sink removing Pony wall becomes Island Plumbing? lothia Plumbing 6 04-30-2013 01:13 PM
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 05:06 AM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 01:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
