Old 02-19-2008, 08:48 PM   #1
Master Plumber
How does this happen?????
I went into the bathroom and turned on the tub ( probably the oldest jacuzzi known to man). Not trying to use the jets or anything....just the tub spout. I waited a little bit and then pulled the knob up to direct the water up to the shower and the tub spout shot off and landed on the bottom of the tub.
Am I cracking up? Is there some Secret Squirrel method for keeping your tub spout on the wall once the equipment gets a little long in the tooth? Pushed that baby back on and- once that knob was pulled up - off it flew again.
Helphelphelphelp...............
Originally Posted by jpplumber View Post
That is because it is loose and when you divert the water to the shower it puts pressure on the spout. There is a set screw on the bottom side of that spout that needs to be tightened....but I always prefer to replace the spout with the kind that threads on, you would have to solder a male fitting on the spout pipe to do that.
Helphelphelphelp.....................
Originally Posted by Mike Swearingen View Post
Tub spouts either screw onto a male threaded fitting on the end of a pipe from the wall, or slide onto a straight pipe from the wall and the spout is held on by an Allen wrench set-screw up in a slot underneath the spout.
You obviously have a slide-on spout that needs the set-screw tightened with an Allen wrench.
Good Luck!
Mike
jpplumber is offline   Reply With Quote
Old 02-19-2008, 09:58 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Boy I screwed that merge up sorry
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 02-19-2008, 10:02 PM   #3
I appreciate the help.
Karen
wifeathome is offline   Reply With Quote
Old 02-19-2008, 10:05 PM   #4
Journeyman Plumber
Well got it kinda straight, at least you know who said what.
Old 02-20-2008, 03:08 AM   #5
Master Plumber
Boy I screwed that merge up sorry.
Ron, maybe that's because you're a plumbing geek and not a computer geek
Old 02-20-2008, 10:18 AM   #6
Long-Time DIYer
Mike Swearingen's Avatar
Yep, and I answered that second post before I saw that she also had posted it a bit earlier and jpplumber had already answered it. LOL
Mike Swearingen is offline   Reply With Quote
Run submerged waterfall pump without water, what will happen herbolaryo Electrical 2 08-15-2007 07:03 PM
What will Happen if I pmb003 HVAC 2 09-21-2005 07:55 AM
