How Does This Faucet Handle Come Off? Pics... - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-07-2009, 06:37 PM   #1
How does this faucet handle come off? pics...
I am trying to help an old neighbor lady stop a leak coming out of her faucet. I confirmed it is the hot water side, but I cannot for the life of me figure out how to take the handle off.
I thank you plumbing experts in advance for any assistance with this. There should be pictures below. Thank you.
I can't find any screw.
How does this faucet handle come off? pics...-faucet.jpg   How does this faucet handle come off? pics...-faucet2.jpg   How does this faucet handle come off? pics...-faucet3.jpg
Timster is offline   Reply With Quote
Old 06-07-2009, 08:35 PM   #2
Have you looked under the sink?
redline is offline   Reply With Quote
Old 06-07-2009, 09:03 PM   #3
GC/Master Plumber/Mech
Rewards Points: 560
Looking at the photos there looks to be a seam about 1/8" down from the top of the handle. The top probable comes off to access the screw that holds the hanlde to the stem
Old 06-07-2009, 09:14 PM   #4
I agree. I did not see it at first as the black tiles left shadows. The top of the handle should be removed to gain access to the screw.
Old 06-07-2009, 10:35 PM   #5
There is no seam on that handle; it is solid but I will definitely double check it.
Also, I did look underneath the sink, but perhaps this thing was just designed wrong.
I was hoping to buy a $1 washer for the lady, not a whole new faucet assembly for $100-200.
I tried unscrewing it. Plumbing store had no idea when I showed the pictures.
I have replaced faucets before quite a bit... never seen something so hard for me to figure out. I guess I will just have to remove the whole handle assembly from underneath the sink, and the old lady may end up buying a whole new assembly, unfortunately.
It just doesn't make any sense that once a washer wears out, the whole assembly needs to be replaced, but I have seen crazier things.
Shoot, I am a licensed GC with a lot of strength in electrical, but not much plumbing; not my strength. My plumber is coming in tomorrow morning on a remodel and maybe he might know.
Thanks for your suggestions.
Old 06-08-2009, 03:48 AM   #6
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Not sure if this will work but try unscrewing the escuchin under the handle. I installed a Moen faucet last week that was designed this way. No handle screws....just the escuchin that held the handle on to the stem.
JDC is offline   Reply With Quote
Old 06-08-2009, 04:15 PM   #7
DIY'r
ScottR's Avatar
Just a shot in the dark, but maybe they're just held down by friction? (Like the knob on a rotary dimmer).
ScottR is offline   Reply With Quote
Old 06-09-2009, 03:39 AM   #8
Dudes, thanks for all the advice.
I can't get back there until Wednesday or Thursday evening, since I am working 'sunrise to sunset' right now on stuff.
I will post what I find. I will try turning the bottome escuchian(spelling?) and pulling the handle off.
I showed the pictures to my plumber today at a small remodel we are doing on a 120 year old mansion here in San Francisco, and he said there had to be a screw there; no screw...
My partner says that it may have been designed to be replaced when the washers wear out.
It is just an interesting thing for me to come across; always like to learn stuff.
I will post my findings in a few days. Thanks.
Old 06-09-2009, 06:30 AM   #9
Rewards Points: 528
It does appear that there is a seam about 1/8 down from the top. But before you use a tool to pry the seam opened, use a mirror and look behind the handle for a set screw. If you have to use a tool to pry it opened, the only one I can think of is a tiny screwdriver.
Work slowly as I think you may also scratch the handle.
rjordan392 is offline   Reply With Quote
Old 06-10-2009, 05:31 PM   #10
Well, I just went over and fixed the leaking faucet. Thanks for all the recommendations.
Anyways, there is no small set screw, since the faucet handle is solid. So I pulled up hard, and the handle popped right off. There is no screw designed to hold it on; it just sits on top.
The eschucheon (spelling?) unscrews if needed to replace the assembly, but I didn't need to do that.
However I did need to replace the corroded faucet stem, but I was surprised nothing was designed to hold the handle on. It works fine though.
Thanks again!
Old 06-10-2009, 07:33 PM   #11
the Musigician
DangerMouse's Avatar
and ScottR wins this round, folks!
DM
Old 06-11-2009, 12:09 AM   #12
Yep, Scott won. I tried everyone's thoughts and Scott's "shot in the dark" worked.
Old 06-11-2009, 02:50 PM   #13
DIY'r
ScottR's Avatar
So this is what it feels like to be right!
It's been so long, I completely forgot.. (I'm married, if you didn't guess ).
Old 06-11-2009, 02:56 PM   #14
Rewards Points: 192
gma2rjc is offline   Reply With Quote
Old 06-11-2009, 03:10 PM   #15
the Musigician
i made a deal with the wife, i'm always right, but it's always my fault. i told her she can't have it both ways.... lol
good call Scott!
DM
Problem removing handle off of Delta Monitor 1400 series tub/shower faucet kcinsj Plumbing 35 10-22-2015 05:02 PM
Faucet handle faces the wrong direction. diyntn Plumbing 1 04-22-2009 09:09 PM
deciphering faucet handle EdPDX Plumbing 1 11-05-2008 08:12 AM
Double Handle versus Single Handle kitchen faucet Lindahoney Plumbing 7 11-20-2007 10:36 AM
