Old 06-13-2009, 02:21 PM   #1
Default How does everyone like shakrk bites?
Just wondering how everyone likes or doesn't them
gomerpyle is offline   Reply With Quote
Old 06-13-2009, 03:16 PM   #2
Yoyizit's Avatar
Shakira? She can bite me anytime she wants to.
Old 06-14-2009, 10:56 AM   #3
I will always consider them a "compression fitting", which in many Codes, have limited usage in homes. The price is not that great, compared to normal compression fittings either.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 06-14-2009, 11:43 AM   #4
I love them although I agree they are a little pricey.They are also not alloud in some areas or you have to make special set up to be able to use them on inside walls.I have been renovating this house for a couple years now but wanted to redo the water line first.Their have been many changes from the start so when I put the fitting in i had to make access panels to the conections or they wouldnt aprove them.Since many pipes had to be moved over time the panels werent such a bad thing after all and being able to reuse the fitting has saved alot of time and money so far no leakes either even when the heat went out in the dead of wither
clasact is offline   Reply With Quote
Old 06-27-2009, 11:03 PM   #5
We pick these?
Default Hoping for the best
I've decided to go with them as they are extraordinarily simple to apply and the cost isn't bad for this one-off project I'm doing. I asked the building inspector here in Indianapolis while he was checking my under-slab drainage if they would be okay to use inside finished walls. His response was that there isn't anything specifically against doing so. I've had some of these fittings under pressure for a month now and no leaks yet. I'm actually using them to replace some lines/ fittings that were soldered improperly. BTW, I'm no plumber, I'm a framer/remodeler doing my own work in the home where I live. Time will tell if sharkbites will hold up...
NailedIt is offline   Reply With Quote
Old 07-03-2009, 02:06 AM   #6
when I got my new service van they had afiew cubbie holes filled with "sharkbite" fittings, at the time I was offended. I mean in 3 years I had not burned down any houses, and no floods, why don't they think I can solder. After using them, they definatly do have their place in my van, just don't think they can replace your B-tank.
plumbob1234 is offline   Reply With Quote
Old 07-03-2009, 08:27 AM   #7
For small jobs they are probably economical, but not for large jobs. And many codes still do not allow them behind walls.
Old 09-02-2009, 04:52 PM   #8
greengiant's Avatar
I just used them repairing a 1" underground supply line. They're difficult to get in place when connecting two straight sections. Seems like you'd need to deflect the pipes a lot to get the coupling in. I ended up using one in a difficult to reach section, and a soldered connection on the other end.
I think they would be super useful for doing temporary repairs. Keeping a few couplings and some PEX on-hand could avoid most emergency calls to the plumber after hours.
Cost-wise, I wouldn't want to do a whole house with them.
greengiant is offline   Reply With Quote
Old 09-02-2009, 07:54 PM   #9
Building codes guy, Mod
thekctermite's Avatar
Just to be clear here...
Sharkbites have ICC-ES approvals for use in burial and concealed locations from the International Code Council (IBC, IRC, IPC), which is the model code that is used in most places these days. Anyone (inspectors or otherwise) telling you that they cannot be concealed in a dwelling needs to do some more research. I believe that they have UPC approvals as well, but can't recall for sure.
I like them just fine and they do have their place, especially with DIYers. Would I plumb a whole house with them? Heck no. That would be crazy for cost reasons if nothing else. They do come in handy for quick repairs or for people that lack the experience or equipment to make more traditional connections.
One consideration that a lot of people fail to think of when using them to connect copper lines in lieu of soldering is that you've got to put a bonding jumper across them (in a lot of cases) since they're nonmetallic. The metal piping system of the house has to be electrically bonded in its entireity and using a Sharkbite interrupts that bonding continuity.
The building code is a minimum standard, and merely meeting it instead of exceeding it equates to building your project to the worst standard that the law will allow.
thekctermite is offline   Reply With Quote
Old 09-03-2009, 01:23 PM   #10
interesting point. glad i decided to learn to solder recently instead of using the sharkbites. i did buy a couple to temporarily terminate pipes. they were great for that.
djrussell is offline   Reply With Quote
Old 09-03-2009, 07:29 PM   #11
WaldenL's Avatar
Love 'em! Especially when it's 10PM, I'm tired, and I've only gotten the cold water soldered because I suck at soldering and I want to go to sleep, but I'd like to take a hot shower in the morning.
WaldenL is offline   Reply With Quote
Old 09-04-2009, 09:39 PM   #12
greengiant's Avatar
They're UPC approved for concealed or underground applications.
For copper-to-copper couplings you can pull the teflon guide out in which case you shouldn't need a bonding jumper, theoretically.
In practice, putting the bonding jumper on is easier than pulling the teflon out, and way easier than trying to convince the inspector you've got a metal to metal union in there.
Old 10-14-2009, 09:02 PM   #13
Hi all, New to this forum. I'm a equipment mechanic for a living but LOVE doing plumbing on the side. Since most people HATE it I often find my services needed. It's a nice sideline. I'm not a pro but a competent amature I would say. I've can sweat copper no problem but working with old crappy pipe is a real challenge. I have used the new push style connectors recently and have mixed feelings about them. While fast, I don't think long term they will last because of the O-ring in them. Modern O-rings are made from some quality stuff no doubt but still fail in the automotive field and I would think that might be the case in plumbing.
That said, Sharkbites and their cousins DO have a place in old work plumbing. Old valves often don't seal 100% and getting the drip from a second story pipe to stop completely can take hours. I use them in this situation. I clean the pipes like I'm going to sweat them( Scotchbrite, emery cloth and them a wipe with tinning fluid). CLEAN and BURR free are essential. For me so far-so good. I won't use them in a closed wall or other (no see) location. They may be OK but I hate come backs. One thing I also don't like is mixing non metalic pipe with copper or brass connectors
because of the difference in rates of expansion between these materials.
The push in connectors come in plastic and I have used them with pex without problems. NEVER leave out the internal sleeve that comes with
fittings or you are inviting trouble. A lot of pro's trash talk these and you can't really blame them for protecting their craft but....... I once met an old plumber that HATED PVC pipe because it cut deeply into his Cast Iron business and would always say "plastic is for toys"........ We all know how well PVC and ABS have changed the plumbing trade. Plumbing like most anything else , works out well when you pay attention to the details. If you don't IT will bite you......like a shark.
LeakyMike is offline   Reply With Quote
Old 10-15-2009, 12:41 AM   #14
Used them to install a new water heater after a "professional" plumber did a cob job sweating and destroying the water heater check valves which I had to replace. What is nice is you can break the seal with the special tool making the next water heater repair a snap and since they require no heat they are safe to use on a water heater.
exrace is offline   Reply With Quote
More On This Topic
Hi this is Fernando we are here with Expert Village and we are going over a sprinkler system and particularly we are going over laying out your pvc before you actually get started. It is very important that you take the time to layout your materials as... Read More »
This area used to be a back porch where the ceiling drops down. This entire area was a back porch. This end segment of it was a laundry room. When we decided to make this an entry alcove, what we did was we had to end the plumbing here, we had to... Read More »
Hi this is Fernando we are here with Expert Village and now we are going over before you actually start installing a sprinkler heads. We have laid down our pvc piping, we have connected our pvc pipes, we have actually done our joining corners and we seal... Read More »
Hi this is Fernando and we are here with Expert Village and again we are going over a watering system and particularly we are go over how much material you need to buy. Now out of the sprinkler, pvc piping, connectors how do you figure out what you need... Read More »
An interesting do-it-yourself project for the garden is constructing a copper arbor. Copper ages beautifully outdoors and enhances any garden decor. Copper is strong and durable and doesn't rust, rot or decompose and requires no maintenance. Here is how... Read More »
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
