How Do You Support A PVC Vertical Run? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-30-2010, 03:09 PM   #1
Rewards Points: 77
How do you support a PVC vertical run?
I am replacing a copper line that comes off a T just outside the house (1/2 in galvanaized penetration) and want to run PVC.
1) My 1st/main concern: The old copper run went to a second spigot (18 in off the ground) around the corner. How does one brace the vertical section up to the spigot?
I can't (yet) find anything on line. I'm assuming I'd brace the brass/galvanized elbow, but where else (how far up the "riser") and with what?
2) Secondly: How low can I go to the grade with the spigot. We have a low window on that side of the house and I'm also putting in the gang & heads for some irrigation lines and we'd like them to not be above the windows?
Is 6-9 in above grade too low?
Thanks!
1655graff is offline   Reply With Quote
Old 08-30-2010, 04:01 PM   #2
Rewards Points: 372
2 hole straps or 1 hole straps
see above
Thanks!
You are welcome
fireguy is offline   Reply With Quote
moving a support wall 6 ft over.? help jstamps Building & Construction 1 04-20-2010 06:48 AM
Temporarily remove basement support post ColinD Building & Construction 14 12-04-2008 06:07 PM
Vertical EMT run - Max length and cable support? ScottR Electrical 3 10-06-2008 02:58 PM
Vertical rebar support. jrepp Building & Construction 6 11-22-2007 06:28 AM
Replacing support beams Annimal76 Remodeling 1 09-10-2007 11:12 AM
