-   -   How do you support a PVC vertical run? (http://www.diychatroom.com/f7/how-do-you-support-pvc-vertical-run-80066/)
1655graff 08-30-2010 02:09 PM
I am replacing a copper line that comes off a T just outside the house (1/2 in galvanaized penetration) and want to run PVC.
1) My 1st/main concern: The old copper run went to a second spigot (18 in off the ground) around the corner. How does one brace the vertical section up to the spigot?
I can't (yet) find anything on line. I'm assuming I'd brace the brass/galvanized elbow, but where else (how far up the "riser") and with what?
2) Secondly: How low can I go to the grade with the spigot. We have a low window on that side of the house and I'm also putting in the gang & heads for some irrigation lines and we'd like them to not be above the windows?
Is 6-9 in above grade too low?
Thanks!
fireguy 08-30-2010 03:01 PM
2 hole straps or 1 hole straps
see above
Thanks!
You are welcome
