Old 02-03-2013, 12:29 PM   #1
How do you remove the center of the kitchen sink drain?
I am trying to remove what I believe is called the strainer of the kitchen sink, but only the top part. My sink is clogged and I want to have a bigger opening for better access with the pipe snake so I would like to remove this part. Below is a picture of the drain and what I am looking to remove is circled in red:
red321 is offline   Reply With Quote
Old 02-03-2013, 12:39 PM   #2
You don't want to remove that,go below the sink and remove the p-trap it's the u shaped part,and rod from there,get a bucket under it before you remove it,because there will be water all over if you dont.
Canarywood1 is offline   Reply With Quote
Old 02-03-2013, 12:40 PM   #3
The strainer isn't usually removed for maintenance but the P or S trap just below it is.
Fairview is offline   Reply With Quote
Old 02-03-2013, 12:43 PM   #4
http://www.bing.com/images/search?q=...electedIndex=0
Old 02-03-2013, 01:07 PM   #5
Roofmaster
That is part of the strainer, and is not removable separately. Try a couple of large pots of boiling water with some vinegar in them first.
" A lot of men build things, and a lot of things fall down "
Old 02-03-2013, 01:11 PM   #6
MarginallyQualified
and try keeping an empty soup or tuna can nearby (mine is in the freezer) for pouring cooking grease into rather than running it down the drain
kitchen sink disposal drain trap problem mystic_cobra Plumbing 20 04-13-2012 10:13 PM
Island sink drain problem oldphoneman Plumbing 2 02-06-2012 11:56 PM
Clogged Kitchen sink drain hornsby Plumbing 2 07-23-2009 10:46 PM
venting kitchen sink drain illinifan Plumbing 2 05-03-2009 08:26 AM
Leaking kitchen sink drain pipe zasior Plumbing 10 01-11-2009 08:22 PM
