How Do I Verify I Have A Broken Drain Pipe. - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-25-2012, 05:04 PM   #1
Question
How do I verify I have a broken drain pipe.
Our kitchen sink and washer share a drain that connects to the main drain under the concrete slab. Perodically the washer backs up in the kitchen sink. We've had plumbers out every 6 months (we've owned the house about 18 months) and they auger the drain then it works ok for about 6 months. This time, the plumber told us his auger couldn't break through so we must have a broken pipe under the slab. (He charged us $187 to tell us this) His solution is to install a pump and pump the kitchen and washer drainage to hook up to the upstairs drain. His estimate is $2850. Does this sound correct?. Is there a way of verifying the pipe is actually broken? Thanks in advance for you input.
printerfixer is offline   Reply With Quote
Old 11-25-2012, 05:07 PM   #2
Rewards Points: 12,790
Hire a plumber that has a camera that can be fed down through a clean out.
Old 11-25-2012, 05:13 PM   #3
I asked our plumber the same thing. He said the drain wasn't big enough to feed a camera through.
Old 11-25-2012, 05:16 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 346
Call around and get some prices for a camera inspection. Some, not all have small cameras that will get to the break location. If they can see the break, they can then locate the camera head by electronic signal. Then you can decide if you want to go into the slab and repair or go the pump route. The age of the pipe might sway you towards a pump or perhaps a new underslab line replacement. Personally, I prefer gravity flow over a pump any day. Call your insurance as well. May be of no help but what can it hurt?
Old 11-25-2012, 05:48 PM   #5
How old is this house.
That would give us an idea on what type was used.
Mine was all done in steel pipe, all the supplys and the drains.
All of then had rusted out and had to be replaced.
Old 11-25-2012, 06:54 PM   #6
The house was built in 1966 and appears to have iron pipes.
Old 11-25-2012, 09:53 PM   #7
Master Plumber
Javiles's Avatar
Rewards Points: 984
i don't understand some of these companies how can they charge if they dont solve the customers problem, if we cant get water draining we don't charge, it can be camera-ed find the right company with proper equipment. look to your home owners insurance it may cover the damage to get to the broken pipe if there is one.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Sand in the drain pipe om221 Plumbing 0 10-08-2012 03:55 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 10:16 PM
Adding washer to basement with no way to vent drain pipe General Plumbing 6 12-26-2010 12:11 PM
Tap 2" Drain Pipe into 4" PVC Main Sewer Drain Pipe brmatthews Plumbing 3 12-20-2010 08:49 PM
AC Coil drain pipe questions fritzycat1 HVAC 14 11-12-2010 04:51 PM
