How Do I Tighten This Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-19-2013, 04:31 PM   #16
Household Handyman
Rewards Points: 1,408
From the original post: "Other valves I've dealt with have a nut right behind the handle but these don't." I agree with others that these valves should be replaced at this time. You will avoid further troubles later.
Old 11-27-2014, 09:18 PM   #17
Rewards Points: 109
Looks like the copper has male threaded connection. Why mess with cutting, soldering, etc... Just turn off main unscrew valve and replace with new one for $7 each. I would go to braided feed lines also. $25 and 15 minutes an you are done and upgraded.
Olcrazy1 is offline   Reply With Quote
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Help w/ mixing valve (I think) ink HVAC 15 02-28-2010 11:01 PM
How to install thermostatic reactive valve and repack supply valve Leah Frances How To Guides 1 06-10-2009 11:49 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
