How Do I Tighten This Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-18-2013, 01:01 PM   #1
How do I tighten this valve?
After turning this valve off to replace my kitchen faucet seals, both are dripping from the yellow handle section when I turn the water back on. Other valves I've dealt with have a nut right behind the handle but these don't. There must be some way to tighten that section! Anyone help me out?
Do I need to pull the yellow plastic handle off?
Thanks,
Mark
phatsupratt is offline   Reply With Quote
Old 04-18-2013, 01:15 PM   #2
Rewards Points: 1,676
After turning off the main water supply, remove the handles, packing nut and the valve stem. You will likely see an O ring on the stem that your local ACE hardware or other favorite store will have. While there purchase a container / tube of water proof plumber's grease and apply a liberal coat to moving parts prior to assembly. That should stop the leak if parts where the O ring resides are cleaned of calcium build up etc.
Old 04-18-2013, 01:19 PM   #3
Thanks Fairview. They never dripped prior to me turning them off/on. Because of that, would I be correct in assuming the O ring is fine?
I'm hoping there is a hex nut or something under the handle that simply needs tightening.
Old 04-18-2013, 01:31 PM   #4
Rewards Points: 744
Probably not. Those angle stops are very old and O-rings split over time. When you turned the knob, the o-ring moved and water is making its way through the split.
I would replace both angle stops with ball valves, but that's just me.
Seattle2k is offline   Reply With Quote
Old 04-18-2013, 02:27 PM   #5
Rewards Points: 14,000
No need for ball valves but I sure would change them for some new 1/4 angle stops.
Old 04-18-2013, 07:44 PM   #6
Rewards Points: 402
When you use the waterproof grease, you might want to wear rubber gloves. Do you know how hard it is to get waterproof grease off your fingers?
taylorjm is offline   Reply With Quote
Old 04-18-2013, 09:32 PM   #7
Lord of Slums
Rewards Points: 1,974
I thought 1/4 turn valves were ball valves
mj12 is offline   Reply With Quote
Old 04-18-2013, 09:44 PM   #8
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Doesn't it have a packing nut under the handle? Why don't you just tighten that up?
Journeyman Plumber
Old 04-18-2013, 10:36 PM   #9
Always learning...
fetzer85's Avatar
Rewards Points: 262
Pretty darn hard with water!
fetzer85 is offline   Reply With Quote
Old 04-19-2013, 01:44 AM   #10
Rewards Points: 744
They are...
Old 04-19-2013, 01:45 AM   #11
Rewards Points: 744
Soap doesn't help?
Old 04-19-2013, 10:49 AM   #12
Roofmaster
Rewards Points: 2,210
Turn off the water main. Cut the pipe immediately behind the valve with a close quarters hack saw with a very fine tooth dull blade (Copper grabs like heck with a new blade, because it is soft. Deburr pipe, and clean with plumbers emory, and sweat on new 1/4 turn ball valves or install compression, or shark bites if you cant solder. Replace supply valves with braided stainless. Trying to repair these old valves is simply not worth it.
Old 04-19-2013, 10:55 AM   #13
747
registered
747's Avatar
Rewards Points: 534
Also grab a couple new braided water lines for the new valves. You have plenty of copper pipe coming out of wall. Changing the valves would be a breeze.
747 is offline   Reply With Quote
Old 04-19-2013, 11:10 AM   #14
DIY staff
Rewards Points: 7,174
Remove the plastic handles and tighten the nut with the valve stem sticking through it----
Old 04-19-2013, 11:24 AM   #15
Plumber
TheEplumber's Avatar
Rewards Points: 808
If for some reason you don't find a packing nut or cant stop the drip- replace the stops with iron pipe stops. No need to cut the pipes- you have male adapters on the supply stubs
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Help w/ mixing valve (I think) ink HVAC 15 02-28-2010 10:01 PM
How to install thermostatic reactive valve and repack supply valve Leah Frances How To Guides 1 06-10-2009 10:49 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
