How Do I Safely Remove This Fitting Please? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-17-2010, 02:41 PM   #1
Rewards Points: 26
I need to temporarily test water flow using a 3/4" and 1" output from service line into house (for sprinkler / irrigation system).
How do I safely remove existing reduction fitting from valve body shown in photo? I'll try using larger wrenches but I think threads are frozen and need to be broken free.
Can I heat valve body or will I risk damaging valve / valve seals? Should I tap on fitting with hammer or will that risk leak between valve body and plastic incoming water line?
Also, I'd like to be able to shut off water at main in event of emergency. I need a pentagonal (five-sided) socket for this. Where do I get one of these and is there anything I need to know about actuating valve at main?
Thanks for help.
diycc2 is offline   Reply With Quote
Old 05-17-2010, 09:32 PM   #2
Rewards Points: 26
No one?
Old 05-17-2010, 11:05 PM   #3
Rewards Points: 1,910
First disconnect at water meter then reducer at valve. Two wrenches. One on reducer, one on valve. Be careful to keep the valve from moving while wrenching so the plastic pipe doesn't get stressed.
remove compound from brass fittings to unscrew fittings purpleheart Plumbing 3 05-08-2010 07:49 AM
Knob and Tube Wiring Question (how to remove a branch safely) Hart2123 Electrical 3 11-01-2009 09:34 AM
Remove fitting from propane line btrevillyan Plumbing 2 06-02-2009 10:55 PM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 06:30 PM
Cracked PVC fitting in concrete DJupin Plumbing 6 07-29-2008 04:12 PM
