Old 07-01-2012, 04:03 PM   #1
How do I replace the tub valves.
I want to upgrade my tub valves and faucet. How do I replace the valves on this tub? I don't not see a way to get to the valves. Picture of tub is on link:
https://picasaweb.google.com/1064090...93657037761570
kcmasterpiece is offline   Reply With Quote
Old 07-01-2012, 05:04 PM   #2
MarginallyQualified
What is on the OTHER side of the wall where the faucets are?
Ideally it's a closet.
Try that again.
Attach the pic directly to this post using the little paperclip icon above
Old 07-01-2012, 05:19 PM   #3
Can't attach pic, exceeded the limit.
Sheet rock and a rafter is on the other side of the wall, that door leads to a closet. I thought the same thing about going in through other side of wall when the exterminator put a vent in the wall near the floor.
Old 07-01-2012, 10:36 PM   #4
Persona Non Grata
VIPlumber's Avatar
No pic in the link.
VIPlumber is offline   Reply With Quote
Old 07-01-2012, 10:45 PM   #5
A rafter is what holds up the roof, how does that come into play with an inside wall?
He put a vent near the floor?
Unless you plan on a complete remodel in the tub area the valves comes out the back side.
Old 07-01-2012, 11:58 PM   #6
There is a post in the wall behind the tub. There isn't a way to reach the valves from the back.
Two pieces of sheet rock and a post before I would reach/see the back of the tub were the valves are.
Old 07-02-2012, 12:19 AM   #7
Renovations contractor
Bonzai's Avatar
Are we talking about the hot/cold taps for the bath tub or the shower/tub control valve? That pic I asked for would really help us to help you as there are 1000's of different types of faucet.
If it's a shower/tub control valve that we are talking about then unless the existing one is a universal model for the particular make you have (ie. can replace just the faucet trim/handle part with something from the same manufacturer) then you need to open up the wall on the bathroom side if there is no access behind.
Home Renovations & Repairs
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
Old 07-02-2012, 12:32 AM   #8
This is a bath tube only.
Here is a link to the picture:
Old 07-02-2012, 12:49 AM   #9
Bonzai's Avatar
Your link still doesn't work
Old 07-02-2012, 07:59 AM   #10
Here you go. Tell me the news that I know I'm not going to like.
Old 07-02-2012, 09:05 AM   #11
MarginallyQualified
Here you go.
It appears that you have a closet next to the tub.
Go in there with a utility knife or keyhole saw.
Open up the sheet rock immediately behind the faucet.
Get to work on the plumbing.
Remember post #2?
There is a post in the wall behind the tub. Two pieces of sheet rock and a post before I would reach/see the back of the tub were the valves are.
Yep. That's what you have to work through/around.
Or the plumber you hire will have to.
Old 07-02-2012, 01:18 PM   #12
I was hoping there would be another way. i was hoping that i would not have to go through that wall. but it looks like I have no choice.
Old 07-02-2012, 01:24 PM   #13
Bonzai's Avatar
Not unless that side panel on the tub comes away relatively easily.
The Following User Says Thank You to Bonzai For This Useful Post:
TarheelTerp (07-02-2012)
Installing shutoff valves syogod Plumbing 3 08-02-2011 11:17 AM
Replace bathroom sink drain? Dave321 Plumbing 2 06-07-2011 01:37 PM
sweat vs compression supply valves JB3 Plumbing 4 02-19-2011 11:53 AM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 02:54 PM
replace galvanized pipe below kitchen sink? Jeremy Hillary Boob, PhD Plumbing 3 04-03-2009 09:39 AM
