-   -   How do I replace the tub valves. (http://www.diychatroom.com/f7/how-do-i-replace-tub-valves-148821/)
kcmasterpiece 07-01-2012 03:03 PM
I want to upgrade my tub valves and faucet. How do I replace the valves on this tub? I don't not see a way to get to the valves. Picture of tub is on link:
https://picasaweb.google.com/1064090...93657037761570
TarheelTerp 07-01-2012 04:04 PM
What is on the OTHER side of the wall where the faucets are?
Ideally it's a closet.
Try that again.
Attach the pic directly to this post using the little paperclip icon above
kcmasterpiece 07-01-2012 04:19 PM
Can't attach pic, exceeded the limit.
Sheet rock and a rafter is on the other side of the wall, that door leads to a closet. I thought the same thing about going in through other side of wall when the exterminator put a vent in the wall near the floor.
VIPlumber 07-01-2012 09:36 PM
No pic in the link.
joecaption 07-01-2012 09:45 PM
A rafter is what holds up the roof, how does that come into play with an inside wall?
He put a vent near the floor?
Unless you plan on a complete remodel in the tub area the valves comes out the back side.
kcmasterpiece 07-01-2012 10:58 PM
There is a post in the wall behind the tub. There isn't a way to reach the valves from the back.
Two pieces of sheet rock and a post before I would reach/see the back of the tub were the valves are.
Bonzai 07-01-2012 11:19 PM
Are we talking about the hot/cold taps for the bath tub or the shower/tub control valve? That pic I asked for would really help us to help you as there are 1000's of different types of faucet.
If it's a shower/tub control valve that we are talking about then unless the existing one is a universal model for the particular make you have (ie. can replace just the faucet trim/handle part with something from the same manufacturer) then you need to open up the wall on the bathroom side if there is no access behind.
kcmasterpiece 07-01-2012 11:32 PM
This is a bath tube only.
Here is a link to the picture:
Bonzai 07-01-2012 11:49 PM
Your link still doesn't work
kcmasterpiece 07-02-2012 06:59 AM
1 Attachment(s)
Here you go. Tell me the news that I know I'm not going to like.
TarheelTerp 07-02-2012 08:05 AM
Originally Posted by kcmasterpiece (Post 955977)
Here you go.
It appears that you have a closet next to the tub.
Go in there with a utility knife or keyhole saw.
Open up the sheet rock immediately behind the faucet.
Get to work on the plumbing.
Remember post #2?
Originally Posted by kcmasterpiece (Post 955881)
There is a post in the wall behind the tub. Two pieces of sheet rock and a post before I would reach/see the back of the tub were the valves are.
Yep. That's what you have to work through/around.
Or the plumber you hire will have to.
kcmasterpiece 07-02-2012 12:18 PM
I was hoping there would be another way. i was hoping that i would not have to go through that wall. but it looks like I have no choice.
Bonzai 07-02-2012 12:24 PM
Not unless that side panel on the tub comes away relatively easily.
