Old 07-21-2010, 11:00 PM   #1
How do I replace the metal U pipe under a sink with a PVC one?
abefroman is offline   Reply With Quote
Old 07-21-2010, 11:15 PM   #2
lloydb's Avatar
You mean the p-trap right? Just do exactly as they've done with the metal but use the plastic trap, plastic nuts and those plastic beveled washers. You can leave the pipe that comes down, but you will probably need to replace the tail piece that goes back towards the wall.
lloydb is offline   Reply With Quote
Old 07-22-2010, 12:11 AM   #3
Thanks!
how to I attach the plastic where it connects to the metal?
Old 07-22-2010, 02:04 AM   #4
lloydb's Avatar
You can use this coupling. Kitchen drains are 1 1/2 and bathroom drains are 1 1/4
Old 07-22-2010, 06:38 AM   #5
the Musigician
DangerMouse's Avatar
Originally Posted by abefroman View Post
Thanks!
The plastic piece (shown) should attach right to the metal coming down.
No need to use a coupler in most cases.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Connecting pvc and metal pipe FrFtr28 Plumbing 18 10-06-2011 08:19 PM
Installing bathroom sink - drains off slightly less than pipe diameter lazzlazz Plumbing 17 05-21-2010 06:12 PM
Drain Pipe about 20 Inches to the right of Vanity Sink mark2741 Plumbing 2 12-16-2009 11:32 AM
Sink drain for new sink. Can't get to plain pipe. rogersmithiii Plumbing 2 07-10-2009 11:24 AM
Help with construction of laundry sink VokinLoksar Plumbing 3 07-06-2008 07:42 PM
