How Do I Replace... - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-29-2010, 04:27 AM   #1
How Do I Replace...
Water is dripping out of these shower faucets. How do I replace them?
jjjoooggg is offline   Reply With Quote
Old 01-29-2010, 08:51 AM   #2
Rewards Points: 20
Is the water dripping from the tap shown in the picture or from the shower head? Replacement usually involves access inside the wall but repairs are easy to this type of tap.
daveb1 is offline   Reply With Quote
Old 01-29-2010, 10:06 AM   #3
Rewards Points: 20
Not sure how new you are but you have now removed all you can without turning the water off.
Old 01-29-2010, 01:32 PM   #4
The water is dripping from the tap in the picture.
I think I can unscrew the tap from the front.
If so I hope I can find a replacement tap for both sides.
Old 01-29-2010, 01:50 PM   #5
Rewards Points: 20
Be sure to turn the water off.Remove the part with the flat edge that needs a wrench or large pliers.Your favourite loosening oil will be handy.Once the part is out you may find it just needs an o-ring replaced.Run your finger carefully inside the part left in the wall checking for rough spots that would tear a new o-ring.If you opt to replace the cartidge part take it to the store with you, many of them look alike but don't fit.If you want to replace both be sure to get a hot and a cold.They both fit the same but turn opposite directions to turn off.Good Luck!!!
Old 01-29-2010, 03:27 PM   #6
Thanks for the info.
Old 02-01-2010, 10:48 PM   #7
The install went well. I went to a place called "plumber's warehouse." I gave them my old parts and they knew what I needed. I wasn't sure if I should use plumber's tape, but I went ahead with it.
Old 02-02-2010, 12:43 PM   #8
Rewards Points: 20
Thanks for posting your results!!Glad it went well for you!!!
Lots of damaged drywall - repair or replace? jdelisle Remodeling 25 04-04-2011 07:37 AM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 02:54 PM
replace galvanized pipe below kitchen sink? Jeremy Hillary Boob, PhD Plumbing 3 04-03-2009 09:39 AM
Pulling up old tile or linoleum to replace it. RyanD General DIY Discussions 4 03-25-2009 01:53 PM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 10:40 AM
