How Do I Repair A Broken Drain Trap - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-03-2012, 06:48 AM   #1
Rewards Points: 117
how do i repair a broken drain trap
Im remodeling my bathroom, when i went to remove my sink i broke the pipe the drain trap screws on to (see pic)
http://img.photobucket.com/albums/v2...ow1/IMG043.jpg
can anyone suggest how and what I can use to fix this? im kinda tight on cash right now and cant afford a plumber and need this fixed before i can continue.
echobravo is offline   Reply With Quote
Old 02-03-2012, 07:17 AM   #2
DIY staff
Rewards Points: 7,174
Can you get at that from below?
That is an S-trap --no longer allowed by code---If you are going to re-do the floor--that could be opened up to access the drain-(if you can't get at it from below)--be a good time to get the pipe into the wall and add a vent or AAV--(air admittance valve)
Old 02-03-2012, 07:18 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,648
Ayuh,... That pipe is Rotten, 'n needs to be Replaced with a new 1...
Cut it off, 'n splice in yer new Pvc...
Bondo is online now   Reply With Quote
Old 02-03-2012, 07:20 AM   #4
'S' traps are still available at home stores, but most codes don't allow them anymore. I see the house is OLD(wood lath plaster), so it might be grandfathered.
Old 02-03-2012, 08:07 AM   #5
Rewards Points: 117
i cant get at it at all.
i am redoing the floor however it has a mud bed under that god awful tile which im not removing so im hoping i can just maybe cut off 180 bend part and use a coupling and new trap?
does this sound like a good idea?
any other suggestions?
Old 02-03-2012, 08:15 AM   #6
DIY staff
That is ,very likely, a 1 1/2" brass tube---standard chrome compression drain fittings should allow you to make a neat coupling---
Old 02-03-2012, 08:57 AM   #7
The toughest thing will be getting a good, square cut on that old pipe. I would be afraid it would split. What is under the floor? There might be a better place to start from.
broox is offline   Reply With Quote
Old 02-03-2012, 10:07 AM   #8
Rewards Points: 117
getting a square cut is what im hoping for without runing the rest of the pipe. if i have to ill wait a week till i can afford a plumber.
i dont know whats under the floor. i cant get to any of it without destroying something else, which isnt what i really want to do.
do they make a coupling that goes from a chrome tube to a pvc tube?
if so whats it called?
or how about using one of those rubber sleeves?
Old 02-03-2012, 06:46 PM   #9
DIY staff
Look in the store where the sink drain pars are---you want a compression coupling---
Short tube with a nut on both ends---will allow you to switch from plastic to chrome--ot chrome to chrome.
You could cut that with a tubing cutter--If you have room--an 1 1/2 stubby one would work--but might cost more than a plumbing call--
Old 02-04-2012, 05:50 PM   #10
Rewards Points: 582
if you are going to redue floor cut pipe under floor roll into wall and install p trap for your vanity or lav...Just my 2 cents ben
Trap and washing machine safety drain pan wildbilly Plumbing 18 03-05-2013 07:08 PM
Help fixing a leak and installing a drain trap. papageek Plumbing 0 12-01-2010 11:23 AM
How far should a P Trap be from the source drain msukazman Plumbing 16 11-12-2010 10:41 PM
controller broken on drain cleaning machine? darsunt Plumbing 3 02-10-2010 03:33 PM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
