How Do I Remove A VERY Old Trip-lever Tub Overflow Cover? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-03-2012, 03:53 PM   #1
How do I remove a VERY old trip-lever tub overflow cover?
I've got a very old (the house was built in the 1930's) tub with a flip-lever drain plug system. The overflow cover does not have the usual two screws on the plate, but just one in the center of the flip lever itself. I've been able to get that screw out, but have not succeeded yet in removing the lever. It is very corroded because apparently the shower head dripped on it for years. My question is - does the cover itself unscrew? Thanks in advance for any help. (Picture attached.)
How do I remove a VERY old trip-lever tub overflow cover?-overflow-cover.jpg
jwnoyes is offline   Reply With Quote
Old 09-03-2012, 07:53 PM   #2
Bombastic Idiot
notmrjohn's Avatar
Be careful, don't damage it, that things cool. I'm guessing, the cover is threaded to tube behind that handle. I don't think handle itself is screwed on. Take screw out, squirt some PB Blaster in there, just a little, have a cloth to wipe dribbles fro tub, but don't think PB is gonna hurt any thing.Let PB work a while, maybe gently tap center of handle with small block of wood. See if you can wiggle/rock handle off with hand. No? Give PB another chance , might can get two strips of wood, one each side of and close to tube under handle. ends of strips padded against tub and gently lever other end out. Mebbee gentle taps with block while doing that. Or. Tie the ends of piece of strong but soft cord together, loop it behind handle both sides of tube wiggle, and lightly tap while pulling doubled cord. Ya might have to go get a faucet handle puller. Oh, should have started with this, but, WHY do you want to remove the cover?
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
The Following User Says Thank You to notmrjohn For This Useful Post:
jwnoyes (09-04-2012)
Old 09-04-2012, 01:26 PM   #3
We gutted the bathroom for a remodel and saved the tub. It's 65 inches long and 18 inches deep, a nice tub. We're going to have it refinished but the overflow cover, handle and drain hardware are all very corroded and need to be replaced (or refinished).
Old 09-04-2012, 08:10 PM   #4
Bombastic Idiot
notmrjohn's Avatar
Can you get to the other side? Cut an acess hole through the wall on other side? If you can find parts to refurbish the insides of faucets and they look as cool as this I would sure try to reuse them. There are retro styles too. When my brother built his house, a big hotel from 20's 30's was being gutted, he scored some huge tubs. Free. All he had to do was get them out of rooms and hotel, lots of other fixtures too. He said place was a mad house. have you given that PB a try? That handle looks kinda fragile be real careful, no hard banging or hard jerks, try to ease it off with all force as close to center as possible.
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 03:53 AM
Central Air Outside Unit Cover czars HVAC 2 01-07-2009 11:23 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 08:34 PM
Broken trip lever in tub cibula11 Plumbing 2 01-28-2008 02:54 PM
lead paint - remove or cover? teresa17603 Painting 8 10-26-2006 07:14 PM
