How Do I Remove This Shower Faucet Cartridge? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-14-2012, 02:44 PM   #1
How do I remove this shower faucet cartridge?
The three attachments show a shower faucet cartridge that is leaking. For the life of me I can't figure out how to remove it. It looks like it should just slide out, but it doesn't. I had to stick my arm up thru an opening to get the side view (several pics taken blind - that was the best one).
I don't know the brand and can't find it on any of the other pieces that I removed.
Thanks in advance.
How do I remove this shower faucet cartridge?-photo.jpg   How do I remove this shower faucet cartridge?-photo-1-.jpg   How do I remove this shower faucet cartridge?-photo-2-.jpg
Tco0085 is offline   Reply With Quote
Old 07-14-2012, 02:50 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
It should pull out. You probably need some vice grips or something to grab onto the stem with : Be careful not to break it.
Usually they have a fair amount of suction behind them and it takes a bit of force to overcome it. You may have to wiggle it a little as you pull, but again : be careful not to break the stem.
Is that a single handle or a 2 handle or 3 handle valve?
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
plummen (07-14-2012)
Old 07-14-2012, 03:04 PM   #3
Two handle. You can see the other valve in the background
Thanks for the quick response.
Old 07-14-2012, 08:06 PM   #4
Doing it myself
Alan's Avatar
They kinda look like delta cartridges to me.... could be a delta or some other off brand that uses delta parts.
Journeyman Plumber
Old 07-14-2012, 08:32 PM   #5
Rewards Points: 582
your right alan its a delta.. op just pull it out ....watch how it come out will need to put back same way... need to replace seat and spring assy...
Old 07-14-2012, 11:14 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Is that a snap ring in 2nd picture?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Need help. 1 shower faucet for 2 shower heads? Downshift93 Plumbing 4 11-08-2011 10:43 AM
Help IDing mini-widespread faucet cartridge Learning Lots Plumbing 0 09-17-2011 06:05 PM
Right tool to remove cartridge of single handle bath sink faucet? darsunt Plumbing 2 05-20-2011 11:01 AM
Faucet Cartridge removal -- what should I have done? RippySkippy Plumbing 9 08-20-2009 09:49 AM
REMOVE worn out STEM TYPE shower faucet... Wafot Plumbing 1 07-04-2009 08:58 PM
