How Do I Remove The Rusty Valve From An Old Cast Iron Radiator? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-30-2011, 11:20 AM   #1
How do I remove the rusty valve from an old cast iron radiator?
I'm removing my 100 yr old cast iron radiators to get them dipped to remove the old paint. while they're out, I'd like to replace the valves. They're all rusted and not working. I have an 18inch pipe wrench on the valve and a 14 inch on the pipe to keep it still (see pic). The valve won't budge. Ive used WD-40 to try to loosen it. How much force can I use on the wrench? Do I risk breaking the pipe Thanks! Rob
Hi folks, here's the resolution to my problem, FYI. I put flame on the valve for about 15 sec, just enough to get it hot. Valve came off no problem after that using the 18 inch and 14 inch pipe wrenches in the pic. Note to home owners, these wrenches are expensive. If you don't have these, lots of equipment rental places rent them out. Good luck!
Jiju1943 thanks much for the advice!
Last edited by robgettings; 08-13-2011 at 10:17 PM. Reason: update photo, resolution of problem
robgettings is offline   Reply With Quote
Old 07-30-2011, 01:00 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 288
Originally Posted by robgettings View Post
I'm removing my 100 yr old cast iron radiators to get them dipped to remove the old paint. while they're out, I'd like to replace the valves. They're all rusted and not working. I have an 18" pipe wrench on the valve and it won't budge. Ive used WD-40 to try to loosen it. How much force can I use on the wrench? Do I risk breaking the pipe Thanks! Rob
Try a torch to heat it, that may work, if it doesn't you may have to cut the pipe and rethread it.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 07-30-2011, 01:10 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 546
I hope you're using 2 wrenches- 1 as a back up
Old 07-30-2011, 01:52 PM   #4
Rewards Points: 1,216
Penetrating oil couple days tapping lightly with a rubber mallet(don't want to break the cast) have patience take your time it's been on there a long time.
COLDIRON is offline   Reply With Quote
cast iron or pvc treerat Plumbing 1 03-29-2011 06:38 AM
How do I shorten a cast iron heat radiator ? garrreee Plumbing 3 12-06-2010 07:26 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
Hot water cast iron radiator valves EHP@WRFD.ORG Plumbing 0 01-10-2009 09:56 AM
Help with Cast Iron Material Tester Plumbing 2 10-25-2007 10:58 AM
