Old 03-06-2012, 11:55 PM   #1
How do I remove this roman tub spout
I am trying to remove this roman tub spout so i can replace it with a new one. It is mounted on the deck of a tub surrounded by tiles. So the only way to access it from underneath is to break through the tiles. I am hoping I don't need to do that and purchased a similar Delta brand trim kit to replace it with.
There is no set screw on the outside of the spout like current models have. I removed the plate from the underside and also two additional screw that were attaching the metal piece you can see to the brass part. However, it still feels well attached to the tub. I am only able to rotate it slightly and it feels like that is moving a whole piece going down in to the tub.
Any help would be much appreciated.
Thanks,
Tim
IMG_1452 by Tim Znamenacek, on Flickr
IMG_1450 by Tim Znamenacek, on Flickr
IMG_1449 by Tim Znamenacek, on Flickr
IMG_1447 by Tim Znamenacek, on Flickr
timz is offline   Reply With Quote
Old 03-06-2012, 11:59 PM   #2
Master Plumber
Javiles's Avatar
Looks like an old delta, mounts from the bottom
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is online now   Reply With Quote
Old 03-07-2012, 12:01 AM   #3
Is there an access panel on that end?
Look under it to see if there's a large nut where the water goes into it.
Old 03-07-2012, 12:07 AM   #4
I'm not sure what end you are talking about for an access panel. There are no access panels that I can see anywhere on the spout or around the tub itself.
Old 03-07-2012, 12:14 AM   #5
Master Plumber
Javiles's Avatar
What are you trying to do replace the complete valve or just the spout? Redressing the trim? Some of those older faucets are hard piped no flexible compression fittings. You’ll need to get under the deck of that tub.
Old 03-07-2012, 11:28 AM   #6
Just the trim - the spout and the handles.
Old 03-07-2012, 12:44 PM   #7
Thanks,
Tim
has to be accesed from bottom..remove locknut and tee assy ...only way to get off
Old 03-07-2012, 09:31 PM   #8
Tom Struble's Avatar
sometimes access panel/cutouts are in a closet in the adjoining room
Tom Struble is offline   Reply With Quote
Old 03-08-2012, 07:59 PM   #9
New user here. I have the exact same spout and am looking to replace it also. I have access to the back side of the tub and found the lock nut and T assembly. Does the entire T junction need to be cut out and replaced? If so what will the new spout mount to? I'm worried this is going to require a new rough-in valve.
I've attached a photo of the T junction.
Thank you for any assistance
Ganthet is offline   Reply With Quote
Old 01-31-2013, 04:14 PM   #10
Where any of you able to resolve the issue? I have the exact same faucet, looking to change the trim and have no access to the deck...
davcamhi is offline   Reply With Quote
Old 02-01-2013, 11:26 AM   #11
I wound up having to cut out the entire assembly and install a new rough-in valve. What I learned was that what I have in my picture above is not a proper rough-in valve, but 2 identical valves soldered together. The spout was also soldered into the junction. I could possibly have removed the spout, but the way my tub is situated the spout did not have room to rotate to unscrew from the junction. A hacksaw and pipe cutter were needed to remove mine. Sorry the news isn't any better.
Old 02-01-2013, 12:36 PM   #12
Thanks, Ganthet. I wonder if Tim (the original poster) had the same configuration, or he had a proper rough in (trying to be optimistic)!
Old 02-01-2013, 07:44 PM   #13
Loosen the nut holding spout to deck of tub then spin the spout out of female adaptor make sure you use a wrench to back the female and go in reverse to put new one on when lined up and tight spin the faucet nut back to tighten spout to deck
joes plumbing is offline   Reply With Quote
Bathtub Spout Replacement cspirit Plumbing 4 03-18-2011 07:39 PM
How to gently remove (aluminum) soffit? superfly Roofing 1 09-06-2009 10:15 PM
Removing tub spout dummy14 Plumbing 20 11-17-2008 12:48 PM
Tub Spout Help showerhelp Plumbing 9 11-13-2008 08:15 PM
Bathtub Spout Leaks Behind Spout (pics) wallix Plumbing 7 10-14-2008 04:41 PM
