How Do I Remove Or Pivot This Piece - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-12-2013, 03:34 PM   #1
how do i remove or pivot this piece
how can i adjust this or move it? i grabbed it with channel locks and i couldnt budge it. Maybe was I not trying hard enough and it should just unscrew? This is under my sink and is the part connected to the wall after the ptrap.
Thanks everyone for your help
neeko13 is offline   Reply With Quote
Old 07-12-2013, 05:56 PM   #2
Rewards Points: 582
hard to make it out from picture ...but i think that abs is glued in ...?ben sr
Old 07-12-2013, 06:05 PM   #3
Rewards Points: 14,300
Pictures so small it's hard to see what it is.
But it looks like an ABS drain line that's glued in place. Only way to adjust it is cut it and use a coupling.
Old 07-12-2013, 07:00 PM   #4
Rewards Points: 2,104
Looks like a trap adapter and that would be glued.
Old 07-12-2013, 09:50 PM   #5
Ok so I think it is glued on because it wont budge. Can someone show me a picture of what to replace it with because the pipe will be coming straight at it now instead of from an angle?
Also where should i cut it at?
Old 07-12-2013, 10:00 PM   #6
Find yourself this tool
https://www.acwholesalers.com/Malco/...FQtY3godcBQAnw
Cut through the pipe in front of the glued hub of the 45
Then Cut the hub of the 45 3 to 4 times without cutting the pipe that is in the hub.
Use a flat blade screw driver and a hammer and pry the old hub off the pipe.
Then replace it with a female trap adapter abs
http://compare.ebay.com/like/3309495...Types&var=sbar
glue it on with abs glue
http://www.pexsupply.com/Hercules-60...FUi33godincArQ
Old 07-13-2013, 03:17 PM   #7
Thank you everyone and specifically Ghostmaker for that very detailed step by step. It was 100% on the money. Ended up only needing to cut it once on the top and then with a flathead I could pry the rest off. Win for my saturday and my first DIY plumbing job. Leak free!
Old 07-13-2013, 07:17 PM   #8
Glad I was able to help. But lot's of good folks here so stay in touch.
How to remove outlet from tiled wall, then patch drywall and retile? Jakobud Kitchen & Bath Remodeling 18 10-15-2011 04:05 PM
Screw holes in vinyl siding piece due to awning removal - fill or replace? mark2741 Building & Construction 9 03-24-2011 12:21 AM
Trying to remove flush mount finish nails pms1228 General DIY Discussions 18 03-15-2011 09:42 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
Removing single piece of siding shortagain Remodeling 4 01-02-2006 10:12 AM
