Old 04-20-2007, 01:52 PM   #1
How do I remove a piece of broken PVC?
I broke off some PVC pipe in the end of a spa filter part. Is there any way I can remove the broken piece? I sure don't want to spend $100 on a new filter.
Thanks!
Geoffro is offline   Reply With Quote
Old 04-20-2007, 05:00 PM   #2
I've done it this way and its worked , take a hacksaw blade by its self no handle and make several cuts in the pipe about a 1/4" apart but don't cut through to into the fitting be carefull then take a fine blade flat screw driver and tap it gently between the pipe and fitting and it should start to lifting out go all the way around until its out , then clean it real good with pvc cleaner . take your time with it .
tzzzz216 is offline   Reply With Quote
Old 04-21-2007, 08:37 AM   #3
Eibwen
You can get a bit to drill it out at your plumbing supply store.
I had somewhat the same situation awhile back but was able to get a coupler on it.
The bits are sized for the pipe and a little pricey 25-30 bucks.
Sammy is offline   Reply With Quote
Old 04-21-2007, 09:59 AM   #4
Journeyman Plumber
Ron The Plumber's Avatar
There called ram bits.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Broken floor flange for toilet billy Plumbing 10 03-13-2008 08:58 PM
How do I remove this ceramic tile? tripower Flooring 5 07-23-2007 10:45 PM
Broken Brake Shoe powrus Automotive Repairs 11 01-16-2007 06:40 PM
Remove baseboard heat? Patrick B HVAC 6 04-11-2006 05:12 PM
Removing single piece of siding shortagain Remodeling 4 01-02-2006 11:12 AM
