-   -   How do I remove a piece of broken PVC? (http://www.diychatroom.com/f7/how-do-i-remove-piece-broken-pvc-7920/)
Geoffro 04-20-2007 12:52 PM
I broke off some PVC pipe in the end of a spa filter part. Is there any way I can remove the broken piece? I sure don't want to spend $100 on a new filter.
Thanks!
tzzzz216 04-20-2007 04:00 PM
I've done it this way and its worked , take a hacksaw blade by its self no handle and make several cuts in the pipe about a 1/4" apart but don't cut through to into the fitting be carefull then take a fine blade flat screw driver and tap it gently between the pipe and fitting and it should start to lifting out go all the way around until its out , then clean it real good with pvc cleaner . take your time with it .
Sammy 04-21-2007 07:37 AM
You can get a bit to drill it out at your plumbing supply store.
I had somewhat the same situation awhile back but was able to get a coupler on it.
The bits are sized for the pipe and a little pricey 25-30 bucks.
Ron The Plumber 04-21-2007 08:59 AM
There called ram bits.
