How Do I Remove A Deep Set Faucet Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-27-2010, 10:08 PM   #1
How do I remove a deep set faucet valve?
My mom's hot water faucet handle and stem completely snapped off. This is the only tub/shower in the house and it has no hot water. As a temporary solution I took an old vacuum cleaner hose and attached it to the bathroom sink. If you want a hot bath you have to slide the hose onto the bathroom faucet and drop the other end in the tub and wait a small eternity to fill up the tub. Well that was 2 years ago! Everyone is sick of taking vacuum cleaner hose showers!
I tried to disassemble the valve but got stuck when I couldn't figure out how to get the broken stem out. The valve is the recessed type. I realize I need a deep set socket wrench but after looking inside the recess I don't see a nut to grab onto. I've read instructions on how to replace the valve but how can I even get it out when there seems to be no nut?
I don't see a nut...do you?
cheapchick is offline   Reply With Quote
Old 07-28-2010, 08:48 AM   #2
Retired Plumbing Cont.
It appears that you removed the bonnet nut. The stem nut may be hidden behind that trim ring. Looks like it might unscrew. See if you can get it off.
Any idea of the brand? Pics of the whole thing including handles and spout might be helpful to I.D.
rockerjockey is offline   Reply With Quote
Old 07-28-2010, 09:05 AM   #3
Owner
LateralConcepts's Avatar
If you're trying to replace it rather than rebuild it, it appears you can just unscrew the brass escutcheon (trim) and pull it out from behind the wall.
Considering its age, it may be difficult to find parts for and may not be a standard 8 inch center, in which case you would need a retro-fit face plate to cover the old holes.
Consider Chicago or Central Brass for a replacement tub/shower kit.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 07-28-2010, 09:47 PM   #4
When I read that it made me think back to when I disassembled it; I did recall removing a large brass nut. I gave what remained of the broken stem 20 seconds of wiggling and out it came...
Thanks!...I just hope the new stem comes with a bonnet nut because the old one has completely disappeared.
The valves I see online don't look like this one. I don't know if I can find a part. The house was built in the mid-50s. But here is a pic of the broken stem...
My mom is supposed to be getting the bathroom redone (probably next year): new tub and faucets, new vanity, toilet, etc. and any kind of way to get the shower working would be appreciated by all until the remodel!
Old 07-28-2010, 10:04 PM   #5
Owner
Take the stem to a wholesale plumbing supply house. If they don't know what it is, they'll have a picture chart to match it up.
Lateral
(208) 818-8241
Old 07-28-2010, 10:10 PM   #6
I was just researching some in the area. I know Home Depot and Lowe's wouldn't have this...I'm keeping my fingers crossed that the stem's intact twin exists somewhere within a 30 mile radius...
Old 07-28-2010, 10:20 PM   #7
Owner
Where are you located?
Lateral
(208) 818-8241
Old 07-28-2010, 10:24 PM   #8
Northeast Ohio...
I was trying to find a match online but when I look up "faucet valve" or "valve stem" so many things come up that aren't it it makes it impossible to sort through and find what I'm looking for...plus it's 50+ years old and there's no manufacturer's name.
Old 07-28-2010, 10:31 PM   #9
Owner
Originally Posted by cheapchick View Post
Northeast Ohio...
Try this
http://www.ferguson.com/FergusonLoca....action?R=1041
If they don't have it, they should be able to tell you who will in your area.
Lateral
(208) 818-8241
Old 07-28-2010, 10:46 PM   #10
Try this
I found a website that has odd stems: http://www.faucetstems.com/index.php
Problem is since the stem is broken I don't know the exact length and how many grooves it has. I'm wary to disassemble the cold water one in case that gets ruined too!
Old 07-28-2010, 10:51 PM   #11
Owner
You'll save yourself a lot of time by just taking them in and talking to a professional
Lateral
(208) 818-8241
How to replace the trigger valve on a Bostich Nail Gun. brokenknee How To Guides 10 11-08-2013 12:25 PM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Washing Machine Faucet handy man88 Plumbing 5 03-23-2009 01:25 PM
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 05:10 AM
White-Rodgers zone valve 1361 wiring ??? srauner HVAC 1 12-06-2008 11:50 PM
