How Do I Remove This? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-28-2012, 05:04 PM   #1
How do I remove this?
I am trying to connect an outdoor sink, but the previous owner of the house connected this garden hose faucet to the copper pipe. I would just leave as is and connect a hose to the sink, but the faucet leaks when it is on. How do I remove it so I can put on a standard angle stop valve?
Here is a photo:
Any help would be greatly appreciated!!!
Dave
Dave 90 YJ is offline   Reply With Quote
Old 06-28-2012, 05:17 PM   #2
Newbie Bill
Rewards Points: 518
Have you tried tightening the nut I circled?
If that doesn't work, you should be able to take it apart and replace a washer or two. We can await experienced plumbers to share their expertise.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
The Following 2 Users Say Thank You to drtbk4ever For This Useful Post:
Dave 90 YJ (06-28-2012), jaydevries (06-28-2012)
Old 06-28-2012, 05:32 PM   #3
Bill, that worked like a charm! Thanks!
Old 06-28-2012, 08:47 PM   #4
Newbie Bill
Rewards Points: 518
Glad it worked.
Bill
Old 06-28-2012, 09:01 PM   #5
DIY staff
Rewards Points: 7,174
If you decide to remove that---drain piping---heat with a touch at the pipe/thread junction--remove when the solder melts.
Old 06-28-2012, 09:53 PM   #6
joed's Avatar
Rewards Points: 11,540
If it starts to leak again then remove the nut and add some teflon packing string and tighten it up again.
How do you remove a wood stove and bricks from living room? SimpleJack Remodeling 13 08-28-2011 02:26 PM
Wrong Sealant used on Unfinished Ceramic Tile... how to remove?! flipjarg Flooring 3 02-15-2010 10:09 PM
best way to remove areca palm root system Dus Landscaping & Lawn Care 0 01-23-2010 10:40 AM
Frigidaire/can't remove front water/ice dispenser tigerfan44 Appliances 0 12-17-2009 11:45 PM
How can I remove my gutter / apron with out pulling the first row of shingels wamyers92 Roofing/Siding 3 07-02-2008 03:10 AM
