Old 03-01-2013, 09:20 PM   #1
How do I properly terminate a vent stack
I am doing some remodeling in the kitchen. The kitchen sink had its own 2" vent stack that went through the roof. I wont be needing it anymore and easily pulled down the 2" pipe out of the roof. Now there is a hole in the roof. How would i properly seal this hole off?
jclee is offline   Reply With Quote
Old 03-01-2013, 09:26 PM   #2
MarginallyQualified
This is a roofing question... not a plumbing question.
The answers will depend on the sort of roofing you have, how much you care about appearance and things like that.
Short term...
something like a metal cap over the boot with good tape will keep the weather out.
Old 03-01-2013, 09:40 PM   #3
Short term...
I forgot to add... I don't want to deal with going on the roof
Old 03-01-2013, 09:47 PM   #4
MarginallyQualified
Ever hear of the Rolling Stones?
They did a great song on this issue.
http://www.youtube.com/watch?v=XIX0ZDqDljA
Old 03-01-2013, 09:55 PM   #5
So you pulled the pipe out and now have a 2" hole in the roof but to not want to get on the roof and fix the hole
Sorry not going to happen. Someone's going to have to get up on the roof to fix it, how depends on what type roof it is.
Old 03-01-2013, 09:57 PM   #6
Roofmaster
Look before you leap, in this case, think before you yank.
Option 1: Go in the attic, glue on a cap and shove the pipe back up there. Im assuming a rubber All-Vent?
Option 2, The Right way: Remove the flashing, cover the hole with sheet metal and properly install shingles. You did have them leave you a square or so when you had the roof done, right?
Scardy Cat!
" A lot of men build things, and a lot of things fall down "
Old 03-01-2013, 10:06 PM   #7
An old Tradesmen
Moved to Roofing forum.
Rusted through Cast Iron Vent stack edros Plumbing 2 09-23-2012 05:26 PM
question about vent stack firstimereno Plumbing 7 05-22-2012 11:47 PM
vent stack for kitchen sink Knucklez Plumbing 4 04-02-2008 07:49 PM
leaking vent stack joint xrayman Plumbing 10 03-04-2008 04:23 PM
