-   -   How do I properly terminate a vent stack (http://www.diychatroom.com/f7/how-do-i-properly-terminate-vent-stack-173336/)
jclee 03-01-2013 09:20 PM
I am doing some remodeling in the kitchen. The kitchen sink had its own 2" vent stack that went through the roof. I wont be needing it anymore and easily pulled down the 2" pipe out of the roof. Now there is a hole in the roof. How would i properly seal this hole off?
TarheelTerp 03-01-2013 09:26 PM
This is a roofing question... not a plumbing question.
The answers will depend on the sort of roofing you have, how much you care about appearance and things like that.
Short term...
something like a metal cap over the boot with good tape will keep the weather out.
jclee 03-01-2013 09:40 PM
Short term...
I forgot to add... I don't want to deal with going on the roof
TarheelTerp 03-01-2013 09:47 PM
Ever hear of the Rolling Stones?
They did a great song on this issue.
http://www.youtube.com/watch?v=XIX0ZDqDljA
joecaption 03-01-2013 09:55 PM
So you pulled the pipe out and now have a 2" hole in the roof but to not want to get on the roof and fix the hole:eek:
Sorry not going to happen. Someone's going to have to get up on the roof to fix it, how depends on what type roof it is.
jagans 03-01-2013 09:57 PM
Look before you leap, in this case, think before you yank.
Option 1: Go in the attic, glue on a cap and shove the pipe back up there. Im assuming a rubber All-Vent?
Option 2, The Right way: Remove the flashing, cover the hole with sheet metal and properly install shingles. You did have them leave you a square or so when you had the roof done, right?
Scardy Cat! :tongue_smilie:
beenthere 03-01-2013 10:06 PM
Moved to Roofing forum.
