How Do I Fix This Bloody Leak? (Laundry Sink) - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-28-2012, 10:03 AM   #31
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Originally Posted by Hardway View Post
Use some plumbers putty, roll it into a small rope shape. Put a small amount under the washer and about a ¼” size on top of the washer. Hand tighten the jam nut and the plumbers putty will be pushed out, the putty left should seal it.
Uh wouldnt it be better/easier just to get the right parts and install them?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 01-28-2012, 10:13 AM   #32
Sure would, but from the pix it looks like he has the right tail piece and the right washer. The strainer looks flat, before replacing the sink worth a try.
Hardway is offline   Reply With Quote
Old 01-28-2012, 10:20 AM   #33
plummen's Avatar
Why replace the sink,just get the right parts and lower it a couple inches on each side
Old 01-28-2012, 10:26 AM   #34
I don't have access to the sink, so I don’t know what the problem is. Just given some ideas that may work.
Old 01-28-2012, 10:30 AM   #35
Lower the sink???????????????? why?
Old 01-28-2012, 11:29 AM   #36
Plumber
TheEplumber's Avatar
Rewards Points: 806
Look at post #12 The flange is not square to the strainer. Maybe the rigid 90 is the issue. Perhaps adding a short tailpiece before the 90...
The Following User Says Thank You to TheEplumber For This Useful Post:
Eusibius2 (01-30-2012)
Old 01-28-2012, 11:53 AM   #37
Yes I saw that the flange is not square, how ever not seeing the whole trap. If the rest of the trap is not tight and connected, that shows nothing!
Your move.
The Following User Says Thank You to Hardway For This Useful Post:
Old 01-28-2012, 04:28 PM   #38
plummen's Avatar
Lower the plumbing,not the sink
The Following User Says Thank You to plummen For This Useful Post:
Old 01-29-2012, 08:19 AM   #39
still remodelling....
The follow up:
I added some putty to the inside of the strainer where it wasn't flush with the pipe / nut. Pic attached. Seems to have worked, but now my clogged drain is back. Which started the whole damn thing. Ugh.
So, today I'm going to snake it again, and then finally call a plumber to fix it if this doesn't work.
Thanks for all the help yesterday. I really appreciate it!
Eusibius2 is offline   Reply With Quote
Old 02-28-2012, 02:22 PM   #40
It looks to me like the pipe under the strainer is not `square' but is cocked a little. Try disconnecting all of the piping attached to the pvc directly under the sink then tighten the nut with the `hat' washer. That should give you a clue as to whether or not the piping is `square'.
I would try pipe dope on the threads of the nut and maybe even some on top of the hat washer but squaring up the piping would help more than anything.
I've had the same leaking trouble several jobs and it is frustrating.
Richard60463 is offline   Reply With Quote
Draining laundry sink into washer stack? glamgirrl Plumbing 33 12-31-2011 02:02 PM
Installing utility sink in laundry room 71Whaler Plumbing 9 11-24-2011 10:33 AM
Slow leak under kitchen sink cdruet Site Help and Suggestions 6 09-06-2010 07:28 PM
Leak in a bathroom sink zach4u Plumbing 3 10-06-2009 07:18 PM
Installing Utility Sink In Laundry Room - Main Floor pieman312 Plumbing 13 01-09-2008 08:13 PM
